Axle Transplant - JeepForum.com
post #1 of 17 Old 10-20-2007, 01:36 PM Thread Starter
Blade427
Axle Transplant
I'm wondering if the axles from a 91-95 Grand Cherokee will work with the 98 GC limited with the 5.2. They will be comming from a 5.2 (same motor as mines) Someone let me know if this will work, mines are on the way out the door and seems cheaper to get "newer" ones from the bone yard
1998 ZJ 318 176,xxx and still going.
Straight pipe after cat. K&N intake system. High Flow Cat. stock suspention. Slight motor tune. and to top it off some BFG 31's
Blade427 is offline
post #2 of 17 Old 10-20-2007, 02:59 PM
JBN311
I'm not a ZJ guy, but I don't see why it wouldn't as long as the gear ratio is the same. I don't know, maybe you would have to make the driveshaft input different.
-Jesse
2004 WJ Laredo V8, NP242 swapped in, front Dana 30 w/ Vari-Lok, Aussie Locked 44a, BB, 30" BFG A/T's, Tow hooks, Rear Hitch, CB, Better than stock radio/MP3 player.
JBN311 is offline
post #3 of 17 Old 10-20-2007, 03:14 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
93-95 V8 ZJ's came with a D35, 96-98 V8 ZJ's came with a D44a.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #4 of 17 Old 10-20-2007, 04:08 PM
Casper4x4
Casper4x4's Avatar
what do the I6 93-95 come with?
Alonzo "Casper" Gonzalez
1993 Jeep Grand Cherokee Laredo
4.0L Engine w/ 231 TC
IRO 4.5" Lift on Kumho 31" MT
IRO frnt adj. track bar w/ mount
Bilstein 5150 shocks
JKS Quick Disconnects
JCR 1 Ton steering
Addco Front Sway bar
Flowmaster muffler
K&N air filter
2 Pro Comp 2 KC lights on KOR light bar
Coleman roof rack
Coming Soon! Gears and locker!
Casper4x4 is offline
post #5 of 17 Old 10-20-2007, 04:20 PM
CLASH
CLASH's Avatar
the 35
cjcjxhxjc
95 zj, 4.5", 32" bfg at, locked rear.
CLASH is offline
post #6 of 17 Old 10-20-2007, 05:01 PM Thread Starter
Blade427
What modifacations would need to be done? Diffrent drivesharts? diffrent TC?
Blade427 is offline
post #7 of 17 Old 10-20-2007, 06:17 PM
CLASH
CLASH's Avatar
don't swap in a 35. its a waste. just find another 44a
CLASH is offline
post #8 of 17 Old 10-20-2007, 06:34 PM
ArloGuthroJeep
Mr. Hyde!
New drive shaft is needed when swapping between the D35 and D44a...If you're going from 35-->44a you can get it shortened, however if you are going from 44a-->35 you need a new one all together.
post #9 of 17 Old 10-20-2007, 11:10 PM Thread Starter
Blade427
What if I just use the shafts already connected to the 35's? Or will there be a problem with the transfer Case?
Blade427 is offline
post #10 of 17 Old 10-21-2007, 12:35 AM
ArloGuthroJeep
Mr. Hyde!
No idea if you grab the DS from the donor setup...I think that some TC's are thicker then others.
post #11 of 17 Old 10-21-2007, 01:17 AM
FortCollinsZJ
[thread stealing] I will be switching my D35 out for an 8.8 soon... will I need to get a new driveshaft? shorther I'd guess. Or will the stock one fit? I can always push the axle back an inch or two if I must. [/thread stealing]
FortCollinsZJ is offline
post #12 of 17 Old 10-21-2007, 06:45 PM Thread Starter
Blade427
That is what I am wondering, I found axels from a 93 5.2 That have 70k less than mine and plus its cheaper to transplant verses rebuilding the ones I have, I have a 249 TC so...I dont know
Blade427 is offline
post #13 of 17 Old 10-22-2007, 02:36 AM
FortCollinsZJ
Bump... help me.. er.. help us.
post #14 of 17 Old 10-22-2007, 05:38 AM
BLACKzj52
lol just saw the same thread last night
BLACKzj52 is offline
post #15 of 17 Old 10-23-2007, 01:38 PM
theizzardking
Bump Same Qestion But From A 44a To A Ford 9" What All Do I Have To Change?
theizzardking is offline
Going In For A Heart Transplant HeliDoc ZJ Grand Cherokee Forum 12 11-05-2009 03:21 PM
44a transplant muckcityjeep ZJ Grand Cherokee Forum 12 06-04-2009 03:07 PM
ZJ outer mirror transplant davidt50 ZJ Grand Cherokee Forum 9 03-14-2009 02:35 PM
4.0l transplant ribwork ZJ Grand Cherokee Forum 5 01-03-2005 02:58 AM
HELLO...I'm a transplant from JU and NAGCA SMAC ZJ Grand Cherokee Forum 2 07-03-2002 02:41 AM
