axle swap in wj - JeepForum.com
post #1 of 14 Old 01-03-2010, 09:13 PM Thread Starter
Nick2000wj
axle swap in wj
Im looking to upgrade the dana 35 out of my 6 cylinder wj...i was thinking of swapping out my axles with v8 wj axles. i am just wondering if the dana 44a out of a wj bolts right in or if i am going to run into problems.
Nick2000wj is offline
post #2 of 14 Old 01-03-2010, 09:14 PM
g-off70
as long it is a wj 44a, it is a direct bolt in
g-off70 is offline
post #3 of 14 Old 01-03-2010, 09:16 PM Thread Starter
Nick2000wj
thanks. also just wondering if there were any years where the v8 wj came with a hp 30 in the front?
post #4 of 14 Old 01-03-2010, 09:30 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
The front axle was low pinion across all the model years for the WJ.
Wheelin98TJ is offline
post #5 of 14 Old 01-03-2010, 09:48 PM
the88thpianoman
2003 WJ
It will be a bolt in if it has the same 3.55 gear ratio. Most likely it will have 3.73 gears, and then you will have to either regear the front axle, or swap that as well. Your gear ratios must match front and rear.
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here:
the88thpianoman is offline
post #6 of 14 Old 01-03-2010, 10:07 PM
Wheelin98TJ
JEEP FREAK
I'm not sure its worth the effort because of the lack of aftermarket support for the 44a.
The slightly lower 3.73 gear ratio would be nice, but its not much of a change from 3.55 and its still a little high for 32" or larger tires.
Are there any upgraded axle shafts available for the WJ D35?
post #7 of 14 Old 01-03-2010, 10:14 PM
perfectcircle
I did the full swap after grenading my diffs last year. The 44a will bolt right in, no issues except gear ratio and the drive shaft. The pinion neck on the 44a is longer than that of the 35, therefore your driveshaft will be a bit too long. Just get it cut to size after the axle is in.
wheelintj - it isn't the aftermarket support that people look at for the 44a swap, it's the all around stronger axle (minus the aluminum pumpkin). Truss the 44a and you're good to go.
perfectcircle is offline
post #8 of 14 Old 01-03-2010, 10:30 PM
Wheelin98TJ
JEEP FREAK
The strength increase with the 44a is certainly a benefit, but the lack of aftermarket support is a pretty big downfall.
If you could add 30 spline chrome moly axle shafts and a 30 spline locker to a WJ D35, I think that is a route definitely worth considering.
The 30 spline D35 chrome moly axle shafts are stronger than a stock D44a axle shaft.
If you do not want a locker, I don't think an axle upgrade is necessary.
post #9 of 14 Old 01-04-2010, 12:43 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
All the WJ axles are red headed step children. Axle shafts need to be custom ordered if you want high strength. Nothing off the shelf for increased spline count.
The 44a is still better all around than a WJ d35, even with only one locker and LSD available.
ratmonkey is offline
post #10 of 14 Old 01-04-2010, 07:13 AM
Wheelin98TJ
JEEP FREAK
I agree that the 44a is a better axle, but I would say its only slightly better.
I'm just not sure its worth the effort and cost, especially if you also have to do the front axle or regear it.
post #11 of 14 Old 01-04-2010, 10:33 AM
WJ04
Like said the 44a (44HD)is a direct swap but you have to make sure the front gears match the rear gears. Also you most likely have to shorten your rear drive shaft or get a new one. The 44a has some week points but is stronger than a regular d44, its a great axle and more comparable to a d60 thats why its also called a 44HD, if you truss and skid it you eliminate the week points and will have yourself a great swap.
Some specs to compair:
Dana 35
Ring Gear Diameter = 7.56"
Pinion Shaft Diameter = 1.406"
Ring Gear Bolt Count = 8
Pinion Spline = 26
Cover Bolts = 10
Axle Shafts = 27 Spline
Axle Shaft Diameter =
Axle Housing Diameter = 2.625"
Carrier Break = 3.31 and down; 3.55 and up
Dana 44A
Ring Gear Diameter = 8.5"
Pinion Shaft Diameter = 1.625"
Ring Gear Bolt Count = 10
Pinion Spline = 29
Cover Bolt Count = 10
Axle Shafts = 30 Spline
Axle Shaft Diameter = 1.25"
Axle Housing Diameter = not sure
Carrier Break = 3.55 and down; 3.73 and up
Dana 44 Iron
Pinion Shaft Diameter = 1.376"
Pinion Spline = 26
Axle Shaft Diameter = 1.19"
Carrier break = 3.73 and down; 3.92 and up
Dana 60
Ring Gear Diameter = 9.75"
Pinion Shaft Diameter = 1.626"
Ring Gear Bolt Count = 12
Pinion Spline = 29
Axle Shafts = 30 (3/4 ton) 35 (1 ton)
Axle Shaft Diameter = not sure
Carrier Break = not sure
This would solve the week spots on the 44a, click on dana 44a truss/skid: Products
2004 WJ Laredo-selectrac 242-I6- Custom XJ intake w/Amsoil cone filter- PSC HD Pump & Res- PSC ported box- B&M trans cooler- B&M PS cooler- Custom chevy 1 Ton over the knuckle steering- Rough Stuff 1 Ton tierod & draglink ends- Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -Relocated OME SD-40 Steering Stabilizer-BDS stabilizer brackets-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Still to come: Flowmaster 50suv
Some of my videos:
Originally Posted by billyjp2 View Post
I burnout on puppies and kittens
Originally Posted by vwmaniacx View Post
Lets not and say we didn't.
WJ04 is offline
post #12 of 14 Old 01-04-2010, 10:57 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
It'll bolt right over, but the drive shaft may be a bit too long (mine was 1" too long).
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #13 of 14 Old 01-04-2010, 11:28 AM
Wheelin98TJ
JEEP FREAK
Dana 35
Pinion Spline = 26
Cover Bolts = 10
Dana 44A
Pinion Spline = 29
Dana 44 Iron
Pinion Spline = 26
Dana 60
Pinion Spline = 29
The 44a and the iron 44 both have 30 spline 1.30" axle shafts.
The only place the 44a is larger than the iron 44 is the pinion shaft diameter/spline count which is an uncommon failure point for both the iron 44 and the D35.
post #14 of 14 Old 01-04-2010, 03:30 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
an iron 44 swap will require welding on brackets(the a-arm attachment will need to be on a truss) and width and bolt pattern changes going into a wj. plus you will most likely lose the rear swaybar which is the most important one on a wj.
the 44a is the most cost effective swap if you want a stronger axle than a d35 in a wj. higher spline chromo shafts would need to be custom made and are likely to be more expensive than an iron 44 swap.
axle brackets for axle swap nicks5.2 ZJ Grand Cherokee Forum 6 07-17-2008 10:38 PM
CJ7 to WJ axle swap the88thpianoman ZJ Grand Cherokee Forum 0 07-06-2008 05:41 PM
axle swap UFO ZJ Grand Cherokee Forum 17 06-29-2007 08:43 AM
front zj u-joint axle shafts a direct swap for cv axle shafts? bjl95mustang ZJ Grand Cherokee Forum 12 05-19-2007 05:57 PM
axle swap randyszj94 ZJ Grand Cherokee Forum 8 08-25-2005 07:33 PM
