Axle swap question - JeepForum.com
post #1 of 4 Old 04-13-2013, 10:11 PM Thread Starter
SpenceAK
Axle swap question
What rear axles are in the wj 4.0 and 4.7 dana 44?
if so is it a bolt in to a 95 zj?
SpenceAK is offline
post #2 of 4 Old 04-13-2013, 10:17 PM
WhiteOut
WhiteOut's Avatar
Rear is not bolt it, you'd need to add brackets for control arms. Front will always be a d30
WhiteOut is offline
post #3 of 4 Old 04-13-2013, 10:31 PM
Mickey_D
The two biggest problems will be :
Gear ratio. The I-6 has a different gear ratio than the the V-8.
Wheel bolt pattern. The ZJ uses a 5 bolt on 4.5" pattern. The WJ uses a 5 bolt on 5" pattern. So if you just plain did an axle swap, you'd have to do both axles or you'd have different wheels on the front and back.
And as said above, the ZJ uses two lower and two upper control arms. The WJ uses two lower control arms, but it has a center mounted "A" arm on the top.
1997 ZJ 5.2 Orvis, Baby!
1953 Willys M100 trailer Tagalong
________________
[_][][][][][][][][_]
#4
Mickey_D is offline
post #4 of 4 Old 04-14-2013, 08:28 AM Thread Starter
SpenceAK
thanks guys
SpenceAK is offline
