Axle swap - JeepForum.com
post #1 of 5 Old 06-09-2013, 06:45 PM Thread Starter
craiglawsonc
Axle swap
My 93 zj is 53007549 / 3-55-610346-4 the donor is a 98 xj 52069194 / 3-55-610758-2 can I swap them out thanks
craiglawsonc is offline
post #2 of 5 Old 06-09-2013, 06:56 PM
dnuccio
Front or rear axle? What gear ratio do you have? Those numbers you posted mean nothing to most of us
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #3 of 5 Old 06-09-2013, 07:04 PM Thread Starter
craiglawsonc
Idk the gear ratio they are fronts the numbers came off the tags
post #4 of 5 Old 06-09-2013, 07:33 PM
Maine1994ZJ
They are both 3.55s. The ZJ has a D30LP(Low Pinion), and the XJ has a D30HP(High Pinion).
IIRC they are interchangeable, not sure if the drive shafts are the same length though.
Check the ZJ FAQ section.
'93 V8 ZJ Mountain Goat Edition.
'95 V8 ZJ Limited, '97 4.0L ZJ TSi
'96 4.0L 2wd XJ, '88 4.2L YJ
Maine1994ZJ is offline
post #5 of 5 Old 06-09-2013, 08:10 PM
riot1987
You can swap an hp in a zj, just make sure your gears match
Build thread^^
riot1987 is offline
