-   -   Axle swap (http://www.jeepforum.com/forum/f13/axle-swap-1534391/)
craiglawsonc 06-09-2013 06:45 PM
Axle swap
My 93 zj is 53007549 / 3-55-610346-4 the donor is a 98 xj 52069194 / 3-55-610758-2 can I swap them out thanks
dnuccio 06-09-2013 06:56 PM
Front or rear axle? What gear ratio do you have? Those numbers you posted mean nothing to most of us
craiglawsonc 06-09-2013 07:04 PM
Idk the gear ratio they are fronts the numbers came off the tags
Maine1994ZJ 06-09-2013 07:33 PM
They are both 3.55s. The ZJ has a D30LP(Low Pinion), and the XJ has a D30HP(High Pinion).
IIRC they are interchangeable, not sure if the drive shafts are the same length though.
Check the ZJ FAQ section.
riot1987 06-09-2013 08:10 PM
You can swap an hp in a zj, just make sure your gears match
The time now is 08:09 PM.
