Quantcast Axle shaft oil seal leaking. Can I just throw in some tube seals? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Axle shaft oil seal leaking. Can I just throw in some tube seals?
Old 01-17-2008, 04:22 PM   #1
bjl95mustang
My ds axle seal is leaking. Can I just toss in a set of These tube seals and be good for now?
http://www.discountjeepparts.com/product_info.php/cPath/2880_76_1175_229/products_id/26047
ZJ 98 5.2 LIMITED De-Badged
4.5" Lift: RE 4.5" springs,Iro rear 3.5 springs+1" spacer, RE shocks, All adjustable arms, IRO front track bar and HD bracket, Rear jks track bar, 1-Ton Steering, 242 tc, 33x12.5x15 GoodYear wrangler silent tires, 15" rock crawler rims, Aussie Locker For My 44A, 760X u-joint front axles.
Soon to come Lock Right Front Locker.
Jeep Inferno member #10
Texas Jeep Club Member #78
bjl95mustang is offline   Reply With Quote
Old 01-17-2008, 04:40 PM   #2
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
i would not recomend it, it is best to just do it the right way the first time.
i had them, and i greased them once, and never again after that, so if you do end up getting them, be shure to grease them like every 2 weeks, other wise, the rubber dissapears.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:http://www.jeepforum.com/forum/f197/5-9-andys-1-ton-zj-build-american-standard-1056365/
5.9 ANDY is offline   Reply With Quote
Old 01-17-2008, 04:50 PM   #3
clgielin
Life is Grand
clgielin's Avatar
2003 WJ
The axle seals can't be more than $15 or so each. You will have more $$$ in gear lube than seals.
Chris
2003 WJ 4.7L
Build Thread Here: 2003 WJ
Michigan Tech Jeepers #4
Utah JeepCrew #16
clgielin is offline   Reply With Quote
Old 01-17-2008, 04:50 PM   #4
TJeeper
No, they are for keeping dirt and water out, not keeping the oil in. You run the risk of filling the housing with oil, allowing the level in the diff to get low enough to ruin the pinion bearing.
Patrick
'99 TJ "Big Jeep"
'98 ZJ "Little Jeep"
TJeeper is offline   Reply With Quote
Old 01-17-2008, 04:54 PM   #5
TJeeper
Originally Posted by 5.9 ANDY
I had them, and i greased them once, and never again after that, so if you do end up getting them, be shure to grease them like every 2 weeks, other wise, the rubber dissapears.
Did you have Alloys? They went through 3 generations of them before they got them right. The first generation I destroyed in 15". The latest set is now about a year old, I grease them every 3k miles.
Patrick
'99 TJ "Big Jeep"
Old 01-17-2008, 05:07 PM   #6
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
no, i have stock XJ axle shafts.
Old 01-17-2008, 05:17 PM   #7
TJeeper
No, I meant were the tube seals from Alloy USA or Superior?
Patrick
'99 TJ "Big Jeep"
Old 01-17-2008, 06:29 PM   #8
bjl95mustang
How hard is it to replace the seals? Any special tools?
Also how hard is it to replace the pinion seal cause that leaks too.
Old 01-19-2008, 02:49 PM   #9
Lostj
this is the method that im going to try today.
http://www.bc4x4.com/tech/2006/dana30-seal-installer/
lx015oɹd uǝpıun 'ɥɔuıʍ ql0009ɟɥ ؛ɹǝıɹɹɐɔ ǝɹıʇ pol 'sɹǝpuǝɟ ǝqnʇ pǝɹɐlɟ"5˙4ʇuʇ :˙ɔsıɯ ؛sɹǝpıls sʞɹoʍʞɔoɹɥs 'pıʞs ǝuıƃuǝ ɔıpǝɯdǝǝɾ 'pıʞs ɹoʇɐıpɐɹ s,ʎʇsnɹ 'ʞuɐʇsɐƃ puɐ xoq ƃuıɹǝǝʇs ʇɥƃıɹuǝƃ :spıʞs ؛pɐoɹɟɟo ɹoɟ sɹǝƃƃoq"53 'ʇǝǝɹʇs ɹoɟ s,ʇ/ɯdɯoɔoɹd"53 :sǝɹıʇ ؛lɯɯ"1 'lq"52˙1 'spq "2 :ʇɟıl ؛ɹǝʌoɔ uǝɯʞoɹ 'loods-ıuıɯ 'sǝʞɐɹq ɔsıp 'sʎollɐ ɥʇıʍ 44p ؛ɹǝʌoɔ ɹǝɥsnɹɔʞɔoɹ 'slɐǝs ǝlxɐ ɹǝʇno 'ɹǝʞɔol ǝıssnɐ 'sʎollɐ /ʍ 03p '6ı :ɾʇ,00
44p '03p '6ı :5ɾɔ,37
s,ʇ/ɐ ƃɟq"23 '44p '03p '8ʌ063 :5ɾɔ,47
The Swamp Things 4x4 Club Jeep Talk HomeGrown Offroad
Lostj is offline   Reply With Quote
Glock Forum
