axle off center - JeepForum.com
post #1 of 5 Old 03-23-2009, 04:07 PM Thread Starter
stiller
axle off center
so i noticed my left side tires go in farther then my right sides do. could this be a cause of death wobble aswell? what part should i buy to center them up. also i was looking at kevins true steering conversion setup, would that be the total solution to saying byebye to dw? if any one is runnin git or knows of anyone can you give me some feed backs on how it is.
the guys here at my local 4wd cant figure out the source of my dw, theyve looked at all my suspension components(supposedly) and i got a ome SS,proper alignments and balancing all that. so im hoping kevins setup will do the trick :]
95' ZJ 4.SLOW I6---3.5 IRO lift
31x10.50 KO's
selling 95' ZJ-$2500 PM me
stiller is offline
post #2 of 5 Old 03-23-2009, 04:12 PM
Greeeeenberg
Adjustable track bar or track bar will fix the off center. Get the adjustable if you ever plan on going higher
Death wobble is caused by worn out parts and or improper installation of said parts. Check your suspension by having someone turn the wheel back and forth while your underneath and look for deflection/play. Check bushings, ball joints, etc etc. You got an alignment after installation?? When was your last tire rotation and balance done? There are so many factors for death wobble. Make a list and start checking them off one at a time.
97 ZJ Orvis 5.2 108K.
Member #1
Greeeeenberg is offline
post #3 of 5 Old 03-23-2009, 04:13 PM
gatorayde
You need an adjustable track bar if you don't already have one.
gatorayde is offline
post #4 of 5 Old 03-23-2009, 04:19 PM Thread Starter
stiller
i have the track bar conversion from IRO that comes with their 3.5 kit. what about a rear adjustable aswell?
31x10.50 KO's
stiller is offline
post #5 of 5 Old 03-23-2009, 04:54 PM Thread Starter
stiller
so noone knows about kors zj true steering setup?
31x10.50 KO's
stiller is offline
Axle Shafts, Gerotor Pumps, Clutch Plates,... oh my! Is my front axle a vari-lok? 99avant WJ Grand Cherokee Forum 16 08-11-2011 08:47 PM
nocked fron axle out of center? FrankTheDank ZJ Grand Cherokee Forum 5 10-31-2009 10:21 AM
Jeep pulls to one side after alignment. Can the rear axle being off center do this? bjl95mustang ZJ Grand Cherokee Forum 5 10-06-2009 02:44 PM
IRO 4.5" Kit Adj. Control Arms Center To Center Measurements? RrCoX22 ZJ Grand Cherokee Forum 8 04-02-2009 11:41 PM
off center axle - adj track bar for 3"? QuadraTokn ZJ Grand Cherokee Forum 21 03-25-2007 05:01 PM
