Axle Nut torque specifications - JeepForum.com
post #1 of 6 Old 07-30-2009, 05:35 PM Thread Starter
GregC
I am replacing the front hub assembly on my 99 Grand cherokee 4x4. I need to know how many lbs. pounds to tighten the 36mm axle nut too. Reason I am asking is because i replaced this hub not much over a year ago and it has already went bad. I want to make sure it isnt something i am doing wrong. Thanks for any help!!
GregC is offline
post #2 of 6 Old 07-30-2009, 08:18 PM
TMCXJ
175 ft.lbs. is the short answer... longer answer is, "brand." Honestly, brands really matter a lot.
"...a long habit of not thinking a thing wrong, gives it a superficial appearance of being right, and raises at first a formidable outcry in defense of custom. But tumult soon subsides. Time makes more converts than reason." Thomas Paine
TMCXJ is offline
post #3 of 6 Old 07-30-2009, 08:19 PM
TMCXJ
Also, welcome to JF!!!
TMCXJ is offline
post #4 of 6 Old 07-30-2009, 10:31 PM Thread Starter
GregC
Thanks for both replys. That should be helpful. The bearing brand I got is Timken. The one I got a year ago came from Advance. It was still under warranty and when i went to get it replaced they couldnt find my warranty info, so I was out of luck. But I was glad to find the Timkens for the same money.
GregC is offline
post #5 of 6 Old 03-17-2011, 08:07 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
For future reference, what Jeep do you have?
Your profile says a 99 Cherokee (XJ), but you said you have a 99 Grand Cherokee (WJ), but you posted in the 93-98 Grand Cherokee (ZJ) forum.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #6 of 6 Old 03-17-2011, 08:14 AM
sebian
You should like the Timkins. A lot of folks on here have said many good things about them, and I just recently put a set on my Jeep. So far they seem pretty good, and I like them!
Welcome to JF!
PS: 175 Ft LBS is the recommended torq spec for the hub nut, so get a few friends and 3 foot breaker bar to tighten that thing up.
1995 ZJ 5.2L V8 318. 230,000 miles and still rollin.
List of parts not replaced yet:
sebian is offline
torque converter and axle swap chevyguy111 ZJ Grand Cherokee Forum 8 04-19-2009 07:24 PM
ZJ axle torque specs Johnyakimo1855 ZJ Grand Cherokee Forum 4 02-17-2009 06:45 AM
'00 Grand Cherokee Torque specifications dorkygrin ZJ Grand Cherokee Forum 3 11-11-2007 11:02 AM
Torque specifications for trailer hitch bolts pgv98 ZJ Grand Cherokee Forum 4 10-16-2004 10:24 AM
