axle ID tag - JeepForum.com
post #1 of 8 Old 12-23-2011, 09:29 PM Thread Starter
lateralus3
1994 ZJ
axle ID tag
how do i decipher the axle ID tag on my hp30? im pretty sure the 3.55 is the gear ratio but the rest im clueless on
Jacob
1994 grand cherokee laredo 4.0 IRO 5.5 critical path long arm kit and OTK steering 35x12.50x15 BFG KM2's
high pinion dana 30 and 8.8 in garage
FOR SALE ONE SET OF ZJ D44A AXLE SHAFTS $150 SHIPPED
lateralus3 is offline
post #2 of 8 Old 12-23-2011, 09:41 PM
freakinheep89
there is nothing else to decipher, really. It is indeed a 3.55 ratio, thus the 3 55 on the tag in the corner.
What did it come out of?
TJ-
95 ZJ 5.2- D30/XJ shafts/D35 Yukon alloys,249, 2"BB, 30x9.5"Wildcat EXT,lots of motor mods, rancho shocks & stabilizer.
Originally Posted by slayercr23 View Post
How would i go about Stroking it?
freakinheep89 is offline
post #3 of 8 Old 12-23-2011, 09:43 PM Thread Starter
lateralus3
1994 ZJ
an xj, i was just trying to figure out what year the axle was
Jacob
post #4 of 8 Old 12-23-2011, 09:49 PM
freakinheep89
Not sure on how to do that. from what ive seen most of them are pretty close to the build date of the jeep.
what year XJ did it come from?
if it has a vac disconnect, its from a pre 92.
TJ-
post #5 of 8 Old 12-23-2011, 09:53 PM Thread Starter
lateralus3
1994 ZJ
no clue, the guy i bought it from bought the housing for the axle shafts then just sold the housing minus the shafts and unit bearings and it does not have vac disconnect so its newer than a 92
Jacob
post #6 of 8 Old 12-23-2011, 10:05 PM
kachink
Manufacturing date should be stamped on cover side of the long tube
http://jeephorizons.com/tech/dana_id.html
kachink is offline
post #7 of 8 Old 12-23-2011, 10:09 PM Thread Starter
lateralus3
1994 ZJ
ah ok
Jacob
post #8 of 8 Old 12-24-2011, 01:05 PM Thread Starter
lateralus3
1994 ZJ
Numbers on the tubes were covered up by paint
Jacob
Front Axle Leaking Inner Axle Shaft Removal? BLEEDNJEEP WK Grand Cherokee & XK Commander Forum 4 05-23-2011 09:11 PM
Front axle noise and thud coming from axle. Not u-joint or Wheel bearing. bjl95mustang ZJ Grand Cherokee Forum 0 07-12-2010 12:10 PM
Axle loud axle whine from D44a jopolly3 ZJ Grand Cherokee Forum 21 04-24-2009 12:51 PM
Does the build sheet say if you have a open rear axle or ls axle? Aussi locker bjl95mustang ZJ Grand Cherokee Forum 28 04-06-2009 08:09 PM
Replacing ZJ axle/hub assemblies - do I have to remove the 36mm axle nut? fmalgapo ZJ Grand Cherokee Forum 11 02-01-2009 03:37 PM
