axle compatibility - JeepForum.com
post #1 of 10 Old 02-22-2006, 11:54 PM Thread Starter
mythic
axle compatibility
Hey all, I am a TJ owner, but asking this question for a friend.
Vehicle in question is a '93 Grand Laredo. Front diff blew up. We are going to replace the front axle. What years/models will fit in his '93?
Thanks in advance!
mythic is offline
post #2 of 10 Old 02-23-2006, 12:05 AM
PumaZJ
Any front end from a 93-98 ZJ, almost any XJ, and TJ's.
1998 ZJ - 36's & bent unibody - RIP
2004 WJ - Expedition build
2011 A4 - DD
PumaZJ is offline
post #3 of 10 Old 02-23-2006, 12:12 AM Thread Starter
mythic
Awesome, thanks for the reply.
mythic is offline
post #4 of 10 Old 02-23-2006, 12:14 AM
PumaZJ
no problem... i'm sure you already know but make sure the gear ratio's match. And try to avoid the vaccuum disconnect (found on some earlier XJ's).
2011 A4 - DD
PumaZJ is offline
post #5 of 10 Old 02-23-2006, 12:18 AM Thread Starter
mythic
Gear ratio isn't a concern. He simply wants it as a rear wheel drive vehicle, so I'm gonna leave the front shaft off. Problem is, it is stuck in 4wheel drive somehow, and he didn't realize it and blew the front diff.
mythic is offline
post #6 of 10 Old 02-23-2006, 06:29 AM
Woody
Retired back to Bowties
Woody's Avatar
1985
What transfer case does your buddy have? There are three possible ones he has. Command trac NP231, Select trac Np242, or Quadra track NP249.
If he has the NP249, removing the front driveshaft is a bad idea. His vehicle will not hold park.
Woody
1985 1 ton K-5, Detroit diesel, 36" tires (going bigger when money permits), 4-speed manual swap, Rockwell T-case, Hybrid lift, 12.5K winch.
Woody is offline
post #7 of 10 Old 02-23-2006, 07:54 AM Thread Starter
mythic
To be honest with you, I don't know. I haven't had the chance to look at the jeep yet, and I'm not too familiar with the ZJ driveline. I beleive that it's the QuadraTrac transfer as he said it's all time 4wheel drive, with only options are 4hi, 4lo and neutral, no 2wd.
So I guess we'll have to get the 'stuck in 4wd' problem sorted out first then.. Thanks again.
mythic is offline
post #8 of 10 Old 02-23-2006, 08:27 AM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
You CAN'T just drop the DS on the T-Case... you better find an axel with matching ratios...
2013 FR-S
BlaineWasHere is offline
post #9 of 10 Old 02-23-2006, 09:14 AM
EMTimZJ
GSMW!
EMTimZJ's Avatar
1994 ZJ
If he has the 249 there is no "stuck in 4wd" that is his only option! (full time 4wd)
Do a search for Viscous Coupler or VC here in this section. TONS of good info.
HTH
-Tim
KD8EBC
'94 ZJ 5.2 LTD
JCR Rock Sliders
EMTimZJ is offline
post #10 of 10 Old 02-23-2006, 09:19 AM
goodolboy71
If its a stock ZJ, then your gonna want to pass on the XJ axle.....Zj's use the LCA mounts on the axle to adjust castor with cam bolts, XJ's use the the LCA mount on the frame side, if you use the XJ axle, your Castor is not adjustable. a Tj axle will work though, or you could use a Xj axle with adjusatble LCA's to set the castor
93 ZJ, 4.0, np242, 4 in F>R , 33's, Arb Bumper, Warn XD 9000, Home depot Rack, lightfoce 170's and some blingy shny 5 star rims,8.8 lsd, d30 /ox locker, JCR Rock Rails
74 CJ5- total restoration from ground up, 3 spd, 304 V8, 32's
goodolboy71 is offline
Axle/Hub Compatibility rnrkid ZJ Grand Cherokee Forum 5 06-01-2009 10:28 AM
WJ Front Axle Shaft Compatibility? CanadianZed-J ZJ Grand Cherokee Forum 13 12-30-2008 08:59 AM
WJ --> ZJ Compatibility Mav ZJ Grand Cherokee Forum 4 11-14-2008 09:01 AM
Quick compatibility question, axle housing UFO ZJ Grand Cherokee Forum 10 04-30-2007 11:11 AM
4.10 Compatibility mr_user ZJ Grand Cherokee Forum 12 01-09-2006 03:50 PM
