axle change question- between WJ & TJ - JeepForum.com
post #1 of 6 Old 01-27-2008, 08:37 AM Thread Starter
genislav ronen
Hello friends,
I own a 1999 WJ ,with Iron Rock 4" lift kit , MX6 Pro Comp shocks,245/75/16 bf mt tires and tom woods hd front drive shaft.
I am quite disappointed from the Quadra-Drive 4-wheel drive system abilities! –
It is not doing what it is suppose to do , and if I may quote from jeep's web site:
"The system instantly detects Tire slip and smoothly distributes engine torque to the tires with traction".
Since I love technical off road wheeling ,
I looked for buying rear and front differential locks,
i found out that the front axle have a lot of diff locks options ,
but for the rear axle the only recommended option available for 44dana aluminum was Aussie Locker which is not for sale anymore.
I heard that the TJ Wrangler / Rubicon axles( 44dana) are suitable for wj and can replace the wj original axles.
The coast for rear and front is around 2500$.
I understood that these tj axles are equipped with advanced and durable technology,
Also they originally comes with diff locks.
If it is true I will want to do just that and change the axles to tj axles.
My question is –did anyone have experience with changing the wj axles to tj axles ?
If yes ,do you need to change or adjust anything in the wj or in the new tj axle in order to make the replacement ?
what are the needed changes adjustments ?
any more info regards this issue will be helpful.
Thanks in advance for your help,
Genislav Ronen
1999 WJ /IRO 6" C.Path LA F&R /clayton's 4 linked rear end /D30-ARB /D44A- Aussie'd /Chromoly U-Joint F.Axle /242hd /4.10's /FOX 2.0 shocks /JKS shock adapters /F.Adj T.Bar /HD double SS/Pitman drop kit /T.Woods F.double cardan d.shaft +pinion yoke&TC yoke /265/75/16 bf mt /Solid HD dana 30 cover/Double open air fillter/ black rock 4" bs /Lower F+R C.Spring Retainers /4" front B. Stops /SUPERCHIP /Addco Rear HD Sway Bar /Rock Sliders /T.case skid plate /HAYDEN hd gear radiator
genislav ronen is offline
post #2 of 6 Old 01-27-2008, 08:48 AM
White_XJ1287
Get axles out of a JK Rubicon. They are the same width and bolt pattern!
White_XJ1287 is offline
post #3 of 6 Old 01-27-2008, 08:55 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
As White_XJ1287 said, you would probably be better off with JK axles.
TJ axles are narrower than WJ axles - about 60" wide on TJ axles vs. 63" wide on WJ axles.
TJ axles are 5 on 4.5 bolt pattern, WJs are 5 on 5.
JK axles are about 65" wide and are 5 on 5 bolt pattern.
Which ever axle you start with, you would have to cut off all the TJ or JK bracketry and weld on WJ brackets.
Wheelin98TJ is offline
post #4 of 6 Old 01-27-2008, 10:40 AM Thread Starter
genislav ronen
thanks ,
i ment tj or jk .
did anyone did it for his wj ?
i have a long arm lift kit- driver y arm ,
will i need to adjust the front axle and prepare new base for the long arms or is it similar to the wj axle base ?
ronen
post #5 of 6 Old 01-27-2008, 01:54 PM
MuddyLuxury
MuddyLuxury's Avatar
you will just simply take the donor axle's and weld WJ brackets on them. and bolt up to the suspesnion.
Call Josh at IRO they are working on a project for it, both front and rear, new front suspesion and a few other goodies
-Jeb
99 WJ 4.7V8 selc-trac swap
285s re-tread
IRO 6.5 Long Arms
Aussie Locked Rear
in the works... lots deployments are great for jeep budgets
Go Doorless!
Things i need..
good spots in the mid atlantic to camp, hike, fish, kyak and wheel, if you know please share
Originally Posted by 5.9 ANDY
i would do the rear.
MuddyLuxury is offline
post #6 of 6 Old 07-30-2009, 07:46 PM
SFCBunnell
Sounds like a change is in the future. I have a question, I just had my rear diff go (2005 TJ Unlimited) What should I do to NOT pay the "car lot" price of 2200.00? I am on a small buget (Soldier) and have to get it fixed.
Thank you...
SFCBunnell is offline
axle fluid change ouikikazz ZJ Grand Cherokee Forum 9 09-21-2009 07:48 AM
Rear axle fluid change kunzet WK Grand Cherokee & XK Commander Forum 1 12-28-2008 08:31 PM
99 front axle change -Joe- ZJ Grand Cherokee Forum 2 12-17-2006 09:03 PM
front and rear axle fluid change question israelshapiro ZJ Grand Cherokee Forum 10 02-08-2006 12:42 AM
How to change axle u joints? theone13 ZJ Grand Cherokee Forum 3 08-04-2005 03:36 AM
