awd 4 low hook up 5.2l - JeepForum.com
post #1 of 15 Old 05-15-2013, 09:26 PM Thread Starter
Marksman113
hey guys, i got a swapped wrangler with a 5.2 and the 36rh tranny. And as of right now its only full time all wheel drive. Where would i hook up the linkage to the transfer case to get normal and then 4lo? i looked but i didnt see a hook up, if possible pics would be great. also if any of you know would a grand cherokee linkage hook up to my wrangler handle. thanks guys
Marksman113 is offline
post #2 of 15 Old 05-15-2013, 09:28 PM
dnuccio
the lever is right next to the front output just like the 231 and 242 cases
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #3 of 15 Old 05-15-2013, 09:52 PM Thread Starter
Marksman113
ok, so locate a small lever thats sticking out near the front output? i really have no idea what itd even look like. Thank you for the quick response
post #4 of 15 Old 05-15-2013, 10:21 PM
dnuccio
circled in red
thats the lever youre looking for
R.I.P. Ratmonkey
dnuccio is offline
post #5 of 15 Old 05-16-2013, 08:19 AM Thread Starter
Marksman113
Thanks so much, I appreciate the help
post #6 of 15 Old 05-16-2013, 08:23 AM Thread Starter
Marksman113
So if I were to get a Zj linkage do you think itd hook right up to my wrangler's 4wd handle? Running a 3in body lift
post #7 of 15 Old 05-16-2013, 08:26 AM Thread Starter
Marksman113
post #8 of 15 Old 05-16-2013, 08:29 AM
speedbucket
Did you swap the whole eng/46rh/transfer case in? If so then you only have 4wd, Neutral, and 4lo. No 2wd
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #9 of 15 Old 05-16-2013, 09:08 AM
dnuccio
i dont think it would work. i would try to find a wrangler linkage or i think novak makes a cable shift kit, which would be an even better option.
R.I.P. Ratmonkey
dnuccio is offline
post #10 of 15 Old 05-16-2013, 05:22 PM Thread Starter
Marksman113
Ok, so a wrangler one would bolt onto the tcase lever? And the Novak, I would get one matching the tcase and it should hook up to the wrangler? Btw I took a look today, found the lever very easily thanks to that picture, thanks again for that.
post #11 of 15 Old 05-16-2013, 05:25 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
ugh. 3" body lift......
no stock linkage you will have available will work with that set up. get a novak...and get rid of that case for a 231....there's a sticky thread with all you need to know to successfully swap in a different case. hope you know the year the v8 came from.
if by "normal" you mean 2wd, you don't have that with that case. only all wheel drive(and if it was an early grand cherokee that has the 46 rh) a non locking 4lo mode.
ratmonkey is offline
post #12 of 15 Old 05-16-2013, 05:28 PM Thread Starter
Marksman113
Ok get a novak matching the tcase and the other end will bolt to my handle? And ya I looked at that but right now it's up for sale and a guy looking at it wanted to know how he could go about hooking up 4low, it's from a 1995
And no I got the 46rh and I mean awd as normal and then 4low
post #13 of 15 Old 05-16-2013, 07:23 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
have you looked at the novak systems?
novak-adapt.com
they do not make a system for the 249 though, no one does. you'd have to make a home brew with that kind of design for the 249. it would be best to swap in a 231 behind that combo to get proper functionality for the wrangler back.
post #14 of 15 Old 05-16-2013, 07:31 PM Thread Starter
Marksman113
Ok, me personally I don't mind just having awd, but the possible buyer guy was wondering how you'd hook it up if he wanted to.
post #15 of 15 Old 05-16-2013, 07:31 PM Thread Starter
Marksman113
And thanks for the link
