AW4 transmission - late shifts when cold - JeepForum.com
post #1 of 5 Old 01-28-2013, 03:41 AM Thread Starter
AVR2
When my AW4 is cold, it takes anything from five to ten seconds to find the gear when going from P to R (which is always my first gearshift when starting in the morning). It also suffers from late shifting from 1 to 2 while cold, and I typically have to lift off the throttle before it will shift (sometimes I have to do this two or three times before I get the first 1-2 shift). Once it's warmed up, everything's fine.
Just to be clear, the trans fluid is recent (I drained and refilled 5 times over a couple of weeks so hopefully there is no old fluid left) and the TV cable is correctly adjusted. I'm assuming that it's just a case of the trans being old, tired and in need of a rebuild, but I thought I'd ask just in case anyone can suggest any cheaper possibilities for a fix, such as solenoids or whatever.
AVR2 is offline
post #2 of 5 Old 01-28-2013, 07:29 AM
Mark05059
let it warm up before heading out.. trans in gear transfer case in neutral and wheels blocked. Idling to "warm it up" does nothing in getting the transmission warm.
1998 ZJ 5.2 Auto
1989 Wrangler Black Bone Stock 2.5l 5spd
/l , [____],
|---L--[]lllllll[]-
()_) ()_)==O=)_)
Mark05059 is offline
post #3 of 5 Old 02-19-2013, 10:09 AM
davidmatlack
Tranny Relay in Power Mgmt Box?
I just replaced this at 254k and feel the tranny is responding faster and smoother. I wasn't having any probelms with it but had just replaced the relay for the AC clutch which was acting up.
best
davidmatlack is offline
post #4 of 5 Old 02-19-2013, 03:59 PM
jnowak
It's a different tranny put same problem. My c6 does that and its a internal leak somewhere in the pump/tc. Over nite the pump/tc drains and has to fill back up. Is there a big thud/jerk when it does go into gear?
jnowak is offline
post #5 of 5 Old 02-19-2013, 04:20 PM
larry33
I had the exat same problem in my 95 zj. I added the lucas stop slip/leak fluid. Over the last 2 weeks i has gotten almost back to normal
larry33 is offline
