Auxillary transmission cooler question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Auxillary transmission cooler question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 07-03-2014, 03:57 PM   #1
capcyclone
capcyclone's Avatar
So I have a '98 ZJ and I've never bothered to add an aux trans cooler - but I'd like to do so this next week. I'm not a big fan of the traditional aux coolers because they mount in front of the radiator and block air flow. If that's the only/best solution - clearly that is what I'll do. Before I do that though - does anyone run one like this - and if so - where did you mount it?
http://derale.com/products/coolers/t...ler-kit-detail
"The Jeep is America's only real sports car" - Enzo Ferrari
capcyclone is offline   Reply With Quote Quick reply to this message
Unread 07-03-2014, 04:23 PM   #2
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
That cooler is very cool.
The problem is space for it. If you put it underneath, it's in harm's way. If you have removed the stock airbox or AC accumulator, those areas could be possibilities. I thought about doing this many times. The lack of space, additional price and complexity of the install kept me from doing it. But I would like to see it done.
HighLonesome is offline   Reply With Quote Quick reply to this message
Unread 07-03-2014, 05:07 PM   #3
capcyclone
capcyclone's Avatar
Yep - those were all my thoughts exactly. I thought I'd ask in case someone has found an original/interesting place underneath that was tucked up enough out of the way.
Unread 07-03-2014, 10:05 PM   #4
PolkaPower
You could probably tuck it up someplace underneath and put a shield on it but you would have to do a bunch of clever trans line routing. The easiest thing to do is to put a large one in front of the condenser. If you think it will hinder cooling, it won't. I have ran mine that way in 110*+ heat in the desert with the A/C running. I bypassed the radiator and it lowered motor temps a little.
PolkaPower is online now   Reply With Quote Quick reply to this message
Unread 07-03-2014, 10:31 PM   #5
zjosh93
You might ask Zjrookie. I recommended that same cooler to him back in April and last I heard he was putting one in.
http://www.jeepforum.com/forum/f13/9.../#post21972345
zjosh93 is offline   Reply With Quote Quick reply to this message
Unread 07-03-2014, 11:43 PM   #6
Zjrookie
I am currently in the process of putting one on similar to that type on between my rock slider rails and it's gunna have a skid plate haven't started project yet been working the demons out of the zj but the unit I am using is the b&m 14000 btu unit with a slim fan and tstat but thing could change based on space
Zjrookie is offline   Reply With Quote Quick reply to this message
Unread 07-04-2014, 09:02 AM   #7
jeepjeepster
I think the same thing about the tranny cooler in front of the condenser. I bought the biggest hayden tranny cooler advance had and installed it. It looks like it takes up almost half of the condenser. I dont use the a/c much at all so that isnt an issue but engine cooling is. Never read of anyone saying the transmission cooler caused any overheating or lack of air flow though.
1994 ZJ-I6 w/216,000 mi
1998 ZJ 5.9 w/65,155 mi Slate Black
2004 KJ w/90,300 mi
jeepjeepster is offline   Reply With Quote Quick reply to this message
Unread 07-04-2014, 01:11 PM   #8
kg6mov
Hears the voices
kg6mov's Avatar
I don't know that I'd try to get too creative with trans cooler location. If the cooler goes it can take the trans with it, so I'd try to leave it where I know it's safe.
1996 ZJ Green Laredo V8, 2.5" OME and Bilsteins, 31's, Holes drilled in the roof.
1998 ZJ Platinum Limited 5.9, New engine and trans, no front driveshaft, but it's pretty
"Whats wrong with a PT Cruiser?"
"Coulda had a V8!"
96 build thread
Niner build thread
kg6mov is online now   Reply With Quote Quick reply to this message
Unread 07-04-2014, 04:59 PM   #9
Zjrookie
Yeah I agree but space is an issue and I want to keep heat as low as possible plus with a skid it will be fine worse case I run the lines back to the rad
Unread 07-04-2014, 06:16 PM   #10
PolkaPower
It's really not necessary. Mine always stayed cool with a big aux cooler in front of the condenser. Even running the ac at full blast in 110* temps.
Unread 07-04-2014, 08:26 PM   #11
jay-h
I have mine spaced a couple of inches in front of the radiator and have seen no difference at all in engine cooling. The trans, however, runs much cooler.
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline   Reply With Quote Quick reply to this message
Unread 07-05-2014, 08:34 AM   #12
LouC
2007 WK
Same as above post, I got a B&M super cooler and used the brackets to space it in front of the AC condenser, no difference in engine temps. The only other place there is room is underneath the rad, you'd need one of the specialty coolers for hot rods to fit one there, and its more vulnerable to small rocks kicked up, sticks etc unless you have the factory front skid plate.
2007 WK Limited Hemi QDII
1998 ZJ Laredo 4.0 Selectrac
LouC is offline   Reply With Quote Quick reply to this message
Unread 07-05-2014, 07:14 PM   #13
Candymancan
I have a 3 loop hayden 24k gvw cooler in front of my condensor and my engine never gets above 195-200f cept in the summer i kinda creep at the 210f mark but it gegs no warmer....
2013 6.2 V8 Camaro SS 4k miles
1998 5.9 V8 ZJ 160k miles
1998 4.0 I6 Laredo ZJ 210k miles
Candymancan is offline   Reply With Quote Quick reply to this message
