Automatic Transmission Fluid Capacity? - JeepForum.com
post #1 of 3 Old 08-01-2006, 02:24 PM Thread Starter
Maverick4
Approximately how much automatic transmission fluid is required for a complete transmission flush for a 2001 Jeep Grand Cherokee Laredo with the 4.0L straight six?
I looked in my manual and I can not find the amount.
While on the topic, what do you all use for the fluid? I'm planning to purchase AMSOIL.
Thanks in advance for the help.
Well, I found the following website via another post in the forum: http://www.wjjeeps.com/service/transmission.htm
Maverick4 is offline
post #2 of 3 Old 08-01-2006, 08:14 PM
rm2001wj
rm2001wj's Avatar
Your transmission is the 42RE, and the 9.5 - 10 qts overhaul amount is at least what you will need. It's your transmision and you can put whatever you want into it, but only AFT+4 (it is now available from makers other than Mopar and cheaper) is what I would use.
rm2001wj is offline
post #3 of 3 Old 08-01-2006, 10:29 PM
John in MA
1994 ZJ
And don't do a power flush. Just let it circulate.
John in MA is offline
WJ Brake Fluid Capacity? 02WJOverland ZJ Grand Cherokee Forum 1 01-05-2009 06:56 PM
'95 --> ATF fluid capacity? zahgurim ZJ Grand Cherokee Forum 1 11-03-2007 11:51 AM
Fluid capacity 249 KingPrat ZJ Grand Cherokee Forum 8 12-27-2006 05:36 PM
Fluid Capacity hrjaw ZJ Grand Cherokee Forum 3 01-11-2005 11:25 AM
A/T Fluid recomendations & capacity ajamie ZJ Grand Cherokee Forum 1 02-22-2004 07:12 PM
