Automatic transmission is dying... - JeepForum.com
 2Likes
  • 2 Post By samse2101
post #1 of 10 Old 10-04-2016, 02:19 AM Thread Starter
samse2101
hi guys,
iŽve a 1996 zj with the 44re transmission in with about 200k miles on it and the following problem:
the misery started one year ago with suddenly decoupled transmission on highway.
i drove about 80mph and without any warning the transmission shifted to "N" -> shift lever still stands on "D"...
the oil level was correct, the oil color and smell was ok too, not burned..
back then i helped to shift to "N" and back to "D" an i could drive along.
Now this problem happend at every longer trip and it doesnŽt help anymore to shift -> iŽve to drive right to the street, stop the car, shut off the engine and restart it (sometimes it works again normal at the first try, sometimes it needs more restarts)
Does anyone have an idea what it could be? IŽm thankful for every input/idea.
IŽve my own garage, so if it necessary to change all switches/solenoids, there will be no problem to do it on my own...
bye,
samse
samse2101 is offline
post #2 of 10 Old 10-05-2016, 04:18 AM Thread Starter
samse2101
no ideas?
post #3 of 10 Old 10-05-2016, 09:23 AM
MrRoundel
When was the last time you dropped the pan and changed your fluid/filter? You might want to see if there is any significant debris in the pan or stuck to the filter. Sometimes things wear to the point of disintegrating, and other times they break, leaving telltale pieces in the pan.
Do you have the Factory Service Manual for your year ZJ? If not, you might want to get one and check the transmission troubleshooting section. It might have something to say about your symptoms.
200K miles isn't a bad run on an auto transmission attached to a V8. Good luck.
1998 Laredo 4.0L 4x4, 242 TC. 195K miles in 7/17. Original owner.
MrRoundel is offline
post #4 of 10 Old 10-06-2016, 12:52 PM Thread Starter
samse2101
the last fluidchange was about 25k miles ago, nothing to see, smelled not burned, but was definitly long used...
iŽve the FSM but it doesnŽt helped me out, so iŽve bought now the following parts:
so lets see what happens after changing them...
bye,
samse
post #5 of 10 Old 10-22-2016, 05:23 AM Thread Starter
samse2101
post #6 of 10 Old 10-27-2016, 09:14 PM
LittleFootZJ
what are they?
LittleFootZJ is offline
post #7 of 10 Old 10-28-2016, 09:05 AM
MrRoundel
Originally Posted by LittleFootZJ View Post
what are they?
They are the transmission's internal pressure switches, solenoid, etc. While I don't think they'll fix the OP's issue, I wish him luck. Hopefully, he'll report back when they are installed, and the ZJ's back on the road for a test drive.
post #8 of 10 Old 10-28-2016, 01:43 PM
paulsheer2
check your shift cable at all points.
check the shift cable bracket -- on the transmission -- that it is tight
check shift cable adjustment -- it should start in N and P and NOT start in any other gear
see my thread: http://www.jeepforum.com/forum/f13/4...ading-3752521/
93 ZJ 5.2, 3.58 stroked. 242 swap. 2.5" lift. dozens of mods.
paulsheer2 is offline
post #9 of 10 Old 10-29-2016, 01:47 AM Thread Starter
samse2101
Hi guys,
like everytime with my jeep -> since iŽve written the thread the transmission works fine....
However today iŽll change the ordered parts and iŽll watch an report if the problem comes again or not.
@ paulsheer2: thx for the tip with the shift cable, iŽll check it today too, the engine starts only in "N" an "P", so this works normal.
good link, havenŽt found it on my own...
bye,
samse
post #10 of 10 Old 10-29-2016, 11:16 AM Thread Starter
samse2101
changed the named parts, made an fluid change too with new filter -> transmission ran fine on the first 100miles until now...
iŽll keep you updated...
bye,
samse
MrRoundel and ROBOTYPHOON like this.
