Automatic Shutdown Relay - JeepForum.com
post #1 of 17 Old 02-26-2010, 08:48 PM Thread Starter
jeeponthebeach
Does anyone know if there are any compatible relays to the ASD? I think my ASD is going bad but I'd like to check before I buy one. Will the AC relay work? I have a 1995 grand cherokee 5.2l.
jeeponthebeach is offline
post #2 of 17 Old 02-26-2010, 09:18 PM
kingvm
kingvm's Avatar
2005 WK
There should be 2 or 3 in the block that are the same as the ASD.
Look at the numbers on them, but I think the AC is one of the ones that are the same.
05 Grand Cherokee Limited, 5.7 hemi, quadradrive II, Nav, 3" lift, JK Rubi wheels/tires, 4xGuard skids
kingvm is offline
post #3 of 17 Old 02-26-2010, 09:20 PM Thread Starter
jeeponthebeach
So look for ones that look similar and have matching numbers and swap it? I dont want to put the wrong one in and have it fry any part electrical system.
post #4 of 17 Old 02-26-2010, 09:25 PM
Savasa
JOB,
Nope, not similar, the SAME. Numbers and everything. Been there done it.
Savasa is offline
post #5 of 17 Old 02-26-2010, 09:28 PM Thread Starter
jeeponthebeach
Originally Posted by Savasa View Post
JOB,
My Jeep hard starts real bad when cold then when it finally starts it runs real ruff and the exhaust smells extremely rich. It also dies out and the rpm run up and down almost to the point of dieing. Could the ASD cause this?
post #6 of 17 Old 02-26-2010, 10:49 PM
ZJJay
ZJJay's Avatar
On my '96 ZJ the following relays are all the same:
Horns
ASD
ABS system
A/C clutch
Fuel pump
Starter
Intermittent wiper
Trans
These are 20A relays, Mopar P/N 4608650, Standard RY612, Tyco 4671168E or 72472M.
Jay
'96 ZJ, 4.0L, 42RE, NP242, stock D30 and D35-LS w/ 3.73, 4-1/2" lift, 32" BFG ATs, Magnaflow, JKS track bars and disconnects, spare tire carrier, Optima red top, ROLA roof rack, KC SlimLite driving lights, CB and Yaesu ham radios, GPS
ZJJay is offline
post #7 of 17 Old 02-26-2010, 11:10 PM
SnowdogMarc
FWIW when I swapped the TBI for the MPI 2.5 last year the old motor did not have the ASD relay. I couldn't get that part of the harness from the donor and just used a standard 30amp relay for it. A relay is a relay...they all work the same but some have a higher currant rating. Been running it as a DD for 6 months now and no problems with anything.
l We're here for a good time. Not a long time. So have a good time the sun can't shine every day.
l_______
/l ,[_____],
l---L -[]lllllll[]-
()_) ()_)--o-)_)____________VE6-SDG
SnowdogMarc is offline
post #8 of 17 Old 02-27-2010, 12:59 AM
ZJ5point2GCL
Just make sure its a bosch style relay, but anything from under the hood will work as long as it fits. but from what you said it doesn't sound like the ASD relay, but its worth a shot.
98 Deep Slate Niner- 6''s on 35's ---11 F150 Platinum Pearl White- Modded Tiny V6 with Two Turbos. ---93 Black 5.2 limited- Slowly dying in my Parents Driveway
ZJ5point2GCL is offline
post #9 of 17 Old 02-27-2010, 01:11 AM
ZJJay
ZJJay's Avatar
No, it doesn't sound like the ASD relay to me either. I had a bad ground on my ASD relay and it just wouldn't start.
If I were you, I'd try to erase the memory in the PCM, just to see if the PCM is the cause. Here's the link to how to do it:
http://www.jeepforum.com/forum/f13/q...et-pcm-948495/
I hope this resolves your problem.
Jay
ZJJay is offline
post #10 of 17 Old 02-27-2010, 11:21 AM
norrisk66
If the engine computer does not recieve the crank sensor signal within a few seconds of cranking-it will disable the ASD relay (which powers up your fuel injectors)
norrisk66 is offline
post #11 of 17 Old 03-05-2010, 03:08 PM Thread Starter
jeeponthebeach
Thanks for all the help and suggestions guys. The reason I'm fixating on the ASD is the Jeep will NOT start at all until I leave the key in the on position for a minute or two then the ASD relay starts clicking for about 30 secs. When it starts clicking the check engine light starts flashing then turns solid. After all that happens the Jeep fires right up but dies out a couple seconds later. After a couple more tries it will stay running but runs super rough and the RPMs jump up and down and the exhaust smells very rich. The ASD may not be the cause of my problem but its defiantly related to it. I figured I'd start there. Haven't been able to work on it because I've been off island.
post #12 of 17 Old 03-05-2010, 07:06 PM
platinum5.9
2003 WJ
if the ASD relay is bad there will be no spark and the Jeep will not start AT ALL. I dealt with this in my 98 after an incident with water..
03 Grand/WJ-White 4.7HO/QD/242HD Clayton 6" LA,5100,Clayton skid,Custom Rockers,JK OME SS,17"Rock Monsters 33"Interco Irok ND,Muffler delete/MF cats,SOLID D30/BTF D44a,Fawkes,Projectors/HID
platinum5.9 is offline
post #13 of 17 Old 03-07-2010, 10:33 AM
norrisk66
I bet you have a bad crank sensor. Mine was doing the same thing-ASD relay was clicking on and off rapidly.
post #14 of 17 Old 04-09-2010, 04:36 AM Thread Starter
jeeponthebeach
Turns out it was the computer. Had it replaced and now it starts right up and run fine at idle to about 18oorpms. After that if you give it gas it has no power. There's a very loud hiss coming from what I think is the IAC. It seems like the motor wants to rev but somethings holding it back. Does anyone know what a malfuntioning IAC would cause? Or could my cat be clogged up?
post #15 of 17 Old 04-09-2010, 05:44 PM
ZJJay
ZJJay's Avatar
When my IAC went bad the idle would fluctuate wildly. I don't know if the IAC would have much effect when you are out of the idle range.
When my cat finally broke apart enough for the pieces to get sideways and clog the exhaust flow, the tone of the exhaust sounded very muffled and the Jeep wouldn't go over 20 mph. Before it got this bad the pieces would rattle loudly.
Jay
ZJJay is offline
auto shutdown relay location? scarbound ZJ Grand Cherokee Forum 6 12-20-2014 04:01 PM
Code 42, Auto Shutdown Relay? zvanit03ru ZJ Grand Cherokee Forum 2 07-09-2009 06:37 PM
Automatic shutdown relay Madgirl ZJ Grand Cherokee Forum 0 12-07-2008 03:36 PM
Fuel Pump Relay/ Auto Shutdown mr_user ZJ Grand Cherokee Forum 10 10-23-2004 11:26 PM
radiator relay and fuel pump relay nobleicon ZJ Grand Cherokee Forum 0 06-11-2002 02:18 PM
