Automatic headlight issue - JeepForum.com
post #1 of 11 Old 06-27-2013, 10:40 AM Thread Starter
esu
Guys, have a 95 ZJ and slowly but surely getting all the nice little doodads to work. Got my VIC and my overhead console up and running and just noticed that I have auto headlights. So I turn the headlight switch to auto, at night of course, and they turn on no problem. They also go off when the jeep is turned off. So far so good. Next day, its still in the auto position and I notice the headlights are on even though its daytime. Is the sensor for this the little round black thing in the middle of my dash? Looks like a real pita to change, probably not worth it. Any thoughts or suggestions or other possibilities?
esu is offline
post #2 of 11 Old 06-27-2013, 11:58 AM
xcaliber81
No the sensor is off to the left a bit under a tiny hole in the vent if you pull up the vent you will see a blue sensor with about 4" of wire.
xcaliber81 is offline
post #3 of 11 Old 06-27-2013, 08:32 PM
vonericsen
xcaliber is correct on it's position. Pull it out and clean it and it will probably work. Just lift the black vent bezel off, then twist the blue sensor out from the bezel and wipe it down with something (or blow it off with something like canned air). Mine had a lot of dust on it making it not work correctly.
Moss Green 95 5.2l ZJ- 5.5" IRO lift, 255 75 R17 BFG M/T on JK Moabs, Mopar ECU, Mopar Tire Carrier
vonericsen is offline
post #4 of 11 Old 06-27-2013, 08:44 PM Thread Starter
esu
Excellent, thx for the info. Will give that a whirl tomorrow and see what happens. Thx Cory.
esu is offline
post #5 of 11 Old 06-27-2013, 10:40 PM
davidtownsend
2006 WK
Is there anyway to make the sensor more sensitive?
1994 Jeep Grand Cherokee 5.2L Limited
2006 Jeep Grand Cherokee Overland 5.7L Hemi
davidtownsend is offline
post #6 of 11 Old 06-27-2013, 11:47 PM
vonericsen
The only thing I can think of is replacing the photo-resistor with one that will have a different resistance in the same amount of light than the one from the factory.
post #7 of 11 Old 06-28-2013, 07:58 AM
davidtownsend
2006 WK
Would you have a link to one?
post #8 of 11 Old 06-28-2013, 08:16 AM
AnotherRedZj
I'll have to look into this.mine Jus turns on the parking lights and fogs in auto, and they Jus stay on. Could have something to do with the dimmer switch too I guess.
One of these days!
AnotherRedZj is offline
post #9 of 11 Old 06-28-2013, 08:31 AM
vonericsen
http://www.digikey.com/scripts/DkSea...sistor&x=0&y=0
post #10 of 11 Old 06-28-2013, 08:35 AM
davidtownsend
2006 WK
Thank you!
post #11 of 11 Old 06-29-2013, 04:19 PM Thread Starter
esu
Ok, pulled that badboy out today and it was just where you guys said and covered with crap. The po didn't clean anything. Anyway, cleaned it off, re-installed and although they do come on at first after a few seconds the lights go off. Now to move on to the next issue, thx again, and happy 4th of July to all.
esu is offline
