Auto Transmission - JeepForum.com
post #1 of 2 Old 07-01-2003, 12:07 PM Thread Starter
jeeptrainee
Auto Transmission
I am helping a friend of mine w/ his 94 Grand Cheroke. The car has been sitting for a while. From what he says, the car was in a shop, and the shop tried to clean a sticking Transmission valve, but didn't do a good job, or the Valve neds replaced. So he has no first gear, and sometimes looses overdrive. I drive a Nissan 240sx w/ a 5 speed, so this is new territory for me. Where is this valve? He mentioned something about a pump too. Is this in the transmission, on the outside, what? I just figured the Jeep gurus could help me on this one. Thanks.
jeeptrainee is offline
post #2 of 2 Old 07-03-2003, 10:11 AM
automan25
Auto transmission can be quite tricky to work on. Personally I'd take it to a reputable transmission shop to have them look it over. About the only thing the lay person can do on an auto trans is change the fluid & filter, and adjust the bands. The bands are what is used to switch gears. If they aren't working correctly, then a gear may feel like it's "slipping" or you may lose a gear entirely. You'll need to refer to a shop manual to find out how to adjust the bands.
The pump on all auto transmissions is built into the torque converter. If the vehicle is drivable at all, then the pump is working fine. If it wasn't then there would be no fluid circulating throughout the transmission, and you'd go nowhere.
1993 ZJ Limited 5.2 - no mods - Red with Gold (what were they thinking) trim.
automan25 is offline
95 zj 5.2l stock transmission auto 428hpzj ZJ Grand Cherokee Forum 0 02-10-2010 08:03 PM
Auto Transmission Trouble - Help! PDX_Rock ZJ Grand Cherokee Forum 1 01-08-2010 09:29 AM
zj auto transmission not working knightyad ZJ Grand Cherokee Forum 1 09-24-2008 08:08 AM
Auto Transmission Fluid ??? CINDY'S 90 XJ ZJ Grand Cherokee Forum 12 07-04-2006 05:35 PM
Auto Transmission Noise lorrick ZJ Grand Cherokee Forum 5 03-30-2006 07:37 AM
