Auto tranny not shifting until Hight RPM problem - JeepForum.com
post #1 of 5 Old 12-14-2001, 11:56 AM Thread Starter
488CID
Hello all, this is my first post on the forum. Unfortunately it is for a problem. I have a 95 GC limited with the quadro-trac trans and it is not shifting into the next higher gear soon enough. It seems to go high in the RPM then shift. It does it sometimes and sometimes it doesn't. But I have noticed that it seems like it is getting worst.
Any help on what this would be great. I did check the tranny fluid and it is full and does not appear burnt or anything.
Thanks for the help and I look forward to being on the jeep forum.
Ed
488CID is offline
post #2 of 5 Old 12-14-2001, 08:53 PM
Kornchild
I am no auto mechanic, but to me is sounds as though the clutch plates in the transmision are worn out (And yes automatics do have clutch plates also) When it does shift is it kinda "soggy", like do you feel it shift or does it just kinda rev and then next gear. If the clutch plates are the problem you need to get the tranny rebuilt at a nice cost of 1500 or you could do it yourself...
Kornchild
Kornchild is offline
post #3 of 5 Old 12-19-2001, 11:42 PM
redneckwithajeep
i have a problem with mine, too. starting out from a stop. it shutters, and shifting into 2nd gear, i can hear a slipping. it never slips except shifting into 2nd, and shifts fine in all other gears! a friend told me something about a "valve body adjustment"???
any help/suggestions appreciated!!!!
'86 xj, 2.8, 3" lift
'94 zj, 4.0, stock (Sadly)
redneckwithajeep is offline
post #4 of 5 Old 12-20-2001, 01:44 AM
Neil
488, I would say it could be your tranny kick down cable.
Redneck, sounds like it's time for a rebuild My Old 93 ZJ was doing the same thing before I had it rebuilt
5.9 ZJ
98 ZJ 5.2
Neil is offline
post #5 of 5 Old 12-21-2001, 08:04 PM
redneckwithajeep
thats what i thought, thanx, niel
ZJ tranny/shifting problems Turbo Drunk ZJ Grand Cherokee Forum 3 05-09-2008 02:54 PM
tranny not shifting TslAtticus ZJ Grand Cherokee Forum 11 12-31-2007 12:14 PM
WJ Tranny: shifting problem during sharp turns JCDubya WJ Grand Cherokee Forum 7 08-05-2007 06:25 PM
tranny shifting shashank ZJ Grand Cherokee Forum 1 12-19-2006 04:24 PM
Auto Tranny Hesitates When Shifting c00lkatz ZJ Grand Cherokee Forum 2 05-08-2004 05:41 PM
