Auto Tranny Hesitates When Shifting - JeepForum.com
post #1 of 3 Old 05-07-2004, 08:40 PM Thread Starter
c00lkatz
Hello,
I'm new to this forum and new to Jeep's altogether. I have a '98 GC Laredo w/ I-6 and Auto tranny, and whenever I move from a start the transmission hesitates from 1st to 2nd, and a little bit from 2nd to 3rd. It also feels like it shifts to 4th a little too early (like right after it shifts to 3rd). It's also rough going into reverse. I've checked tranny fluid level and condition, and all is good. I've also just done a full tune-up on it (stock plugs (Champion RC12LYC, wires (Bosch), cap, rotor, filters, etc). It feels like this problem started shortly after doing the tune-up (when I test drove it, these problems didn't occur and it shifted smoothly, save for the rough reverse). The car has a little over 100k miles on it. What might the problem be? Thanks.
c00lkatz is offline
post #2 of 3 Old 05-08-2004, 07:54 AM
greasefingers
greasefingers's Avatar
1994 ZJ
If your trany is slipping (rpms jump about 1000 higher than they should at the beginning of each new shift), then your trany is shot. Mine did this at 140k miles. I adjusted the bands and changed the fluid with no avail.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of 3 Old 05-08-2004, 05:41 PM
mike57
Hesitating between shifts, shifting early or late are entirely different then slipping between gears (which usually indicates wasted clutch packs and a worn out tranny). Best advice would be to have a competent tranny shop check it out. Chances are it could be something minor if it is not slipping as stated above.
mike57 is offline
94 ZJ 5.2 tranny not shifting correctly gaucho919 ZJ Grand Cherokee Forum 15 03-31-2009 10:59 AM
'97 ZJ Tranny shifting on the highway dkumar1 ZJ Grand Cherokee Forum 2 11-20-2008 03:40 PM
tranny not shifting TslAtticus ZJ Grand Cherokee Forum 11 12-31-2007 12:14 PM
tranny shifting shashank ZJ Grand Cherokee Forum 1 12-19-2006 04:24 PM
Auto tranny not shifting until Hight RPM problem 488CID ZJ Grand Cherokee Forum 4 12-21-2001 08:04 PM
