Auto Headlight sensor - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Auto Headlight sensor
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSave 17.76% for the 4th of july with ruffstuff specialtiesJuly 4th Sale Event! and Yes, We're Open!
Unread 04-13-2011, 11:40 AM   #1
Howieb92
hey again,
another question for auto healdights we need a sesor but now i found a sensor is the conector part to the sesnor already in the jeep or would i have to install that too since mine does not got auto head lights already ?
Howieb92 is offline   Reply With Quote Quick reply to this message
Unread 04-13-2011, 12:29 PM   #2
MStaffin
Thats there. So far almost every jeep is plug and play. Did factory tow wiring on mine and it was there on both zj and wj. Did factory fogs on my zj wires were there. Same with the auto sensor.
00 WJ Zone4in Clayton longarms and linked rearD30/D35 4.88s 33s locked
MStaffin is offline   Reply With Quote Quick reply to this message
Unread 04-13-2011, 12:42 PM   #3
Howieb92
Do you by chance know where it is located?
Unread 04-13-2011, 01:03 PM   #4
MStaffin
Nope I only found out because I pugged in the auto switch plugged in the relay tunred the wipers on and it worked fine. Id do that b4 bying a senosr.
Unread 04-13-2011, 01:06 PM   #5
Howieb92
Sorry could you explain that better I kinda confused.
Unread 04-13-2011, 01:24 PM   #6
MStaffin
Ok what I did was installed my auto headlight switch first. Then installed the auto relay in the fues pannel or it was the fues itself i dont remember. Then I set the switch to auto and turned on the wiper blades and the lights turned on. You may have to set on your dash computer set wipers on lights on setting though. If it dosent work you need sensor. Dont by sensor without trying first.
Unread 04-13-2011, 03:59 PM   #7
Howieb92
O ok thanks.
Unread 04-13-2011, 10:10 PM   #8
Howieb92
So when you say turn the wipers on what that mean they have to stay on. And how is it auto if they are no sensor for then to see of they need it on
[COLOR="Black"][CENTER][SIZE="4"][FONT="Showcard Gothic"][COLOR="Black"][URL="http://groups.jeepforum.com/built-not-bought/"][COLOR="Black"]Built Not Bought #655[/COLOR][/URL][/FONT][/SIZE][/COLOR][/CENTER][/COLOR]
Unread 04-14-2011, 04:12 AM   #9
coralman
I can wish can't I?
coralman's Avatar
Now you have me really confused. What do auto headlights have to do with the wipers? The auto headlight sensor is located in the panel at the rear of the dashpad to right of the left tweeter. Depending on whether the vehicle has factory alarm or not it will also have the red LED for the alarm housed with the sensor. My 98 did not have the pigtail for the sensor, unless its buried under something. Far as I know auto headlights only operate the headlights. I could check the sensor wiring diagram to see where the pigtail terminates to but its too early in the morning for me,lol.
coralman is offline   Reply With Quote Quick reply to this message
Unread 04-14-2011, 06:15 AM   #10
MStaffin
They turn on. Thats how I checked to see if I had the sensor.
Unread 04-14-2011, 06:17 AM   #11
MStaffin
You all ready checked for wiring so it wont mater. But.if your jeep did and you didnt know that way is a fast.test
Unread 04-14-2011, 11:45 AM   #12
coralman
I can wish can't I?
coralman's Avatar
A WJ is a different beast if I'm not mistaken. I could be wrong. The sensor is a ph0tovoltaic type. It senses when the light levels are low by changing voltage to the headlight sense terminal of either the headlight module or the bcm I forget which. This in turn brings on the headlights when the switch is in auto. WJ's came with a rain sensor in the windshield glass {if equipped} that would activate the wipers but I,m not familiar with that circuitry. ZJ's,which is what the op has, didn't.
Unread 04-14-2011, 11:58 AM   #13
MStaffin
I have both wj and zj. Wj had it cause I bought it like that zj was stock.
Unread 04-14-2011, 02:22 PM   #14
Howieb92
I pulled of the top dash peice today at lunch to look under it. And I found two small connectors one on each side I had nothing connected to them so would that be for the sensor and alarm?
Unread 04-15-2011, 11:01 PM   #15
Howieb92
Bump
