Auto Dim rear view mirror - JeepForum.com
post #1 of 17 Old 09-22-2013, 12:47 PM Thread Starter
MrSpooky
Hello, I have a 98 ZJ SE and the auto dimming mirror quick working sometime over the summer. It does not dim and the button on the bottom of the mirror no longer lights up green. Is there a fuse for the mirror or do I need to replace the mirror?
Thanks
Mike
MrSpooky is offline
post #2 of 17 Old 09-22-2013, 03:36 PM
chaZJones
if everything else still works its probably the mirror as the fuse operates multiple things. I recently got one from a junkyard for under $10
96 ZJ 5.2L 156k
chaZJones is offline
post #3 of 17 Old 09-22-2013, 03:38 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
15 amp fuse#6 in the junction block
Originally Posted by HighLonesome
coralman is offline
post #4 of 17 Old 09-22-2013, 03:59 PM Thread Starter
MrSpooky
Thanks for the replies, the owners manual said that the fuse controlled several different things and they are all still working so I will replace the mirror.
MrSpooky is offline
post #5 of 17 Old 09-22-2013, 07:17 PM
jeeepguy
jeeepguy's Avatar
Check the wiring contacts first before changing the mirror. I've fixed two other ZJs this way for other people. The inside mirrors rarely go bad.
"Si Vis Pacem Para Bellum"
"Great danger lies in the notion that we can reason with evil"
Doug Patton
...We use words like honor, code, loyalty. We use these words as the backbone of a life spent defending something. ...I have neither the time nor the inclination to explain myself to a man who rises and sleeps under the blanket of the very freedom that I provide, then questions the manner in which I provide it. I would rather you just said thank you, and went on your way, Otherwise, I suggest you pick up a weapon, and stand a post...
I bought the HI-WAY BLASTER HORN that's 139dB and every time I honk the horn an Angel dies.
Revelation 13:16-18
16 - He causes all, both small and great, rich and poor, free and slave, to receive a mark on their right hand or on their foreheads,
17 - and that no one may buy or sell except one who has the mark or the name of the beast, or the number of his name.
18 - Here is wisdom. Let him who has understanding calculate the number of the beast, for it is the number of a man: (Real ID and RFID chips)
Think about it...
jeeepguy is offline
post #6 of 17 Old 09-22-2013, 07:38 PM Thread Starter
MrSpooky
Check to make sure they are fully plugged into the rear of the mirror? Or check for something like corrosion?
MrSpooky is offline
post #7 of 17 Old 09-22-2013, 08:12 PM
xcaliber81
Mine is always dark even if i unplug it, not even dark just a light brown Im guessing ill have to replace mine as well? All my wiring is good cause i just swapped in the overhead console and the mirror hi lo off still light up.
xcaliber81 is offline
post #8 of 17 Old 09-22-2013, 08:23 PM
Kingr98
2016 JK Wrangler
Mine was always dark also. I even took mine apart to check the photoelectric resisters, but could not figure anything out. The resisters worked, but the mirror never changed.
I found one at a junk yard and the guy even let me plug it in to check it before I bought it. $10 fix!
Kingr98 is offline
post #9 of 17 Old 09-22-2013, 09:57 PM
chaZJones
the reason I replaced mine was somehow an air bubble got into the dimming fluid so part of the mirror was black and the other part was clear. so they do randomly go bad.
96 ZJ 5.2L 156k
post #10 of 17 Old 09-27-2013, 08:30 AM
V65Ozzie
Anyone know if I can swap in one of those dimming mirrors into a ZJ that didn't come equipped that way, is the wiring for the plug there already? I liked the auto dim feature, but my 98 doesn't have one. I know a lot a vehicles have the same harness from the factory, and the options just plug in. FWIW, I had the same issue as the OP on my 97, a JY unit fixed it.
Retreat? Hell, we just got here......
V65Ozzie is offline
post #11 of 17 Old 09-27-2013, 09:30 AM
xcaliber81
I just swapped In the overhead console and the wiring was not there I had to go througb the steps to lower the headliner cut the hole remove part of the dash so I could route the wires, also had to repin the wires cause I took everything from a 93mine is a 94 so 1 connection was different. But the auto dim gets power from the overhead console wiring harness so u may as well grab the overhead console and wiring and swap it in. Took me half the day and having some help is nice too.
post #12 of 17 Old 09-27-2013, 12:35 PM
coralman
coralman's Avatar
my 98 had the wiring tucked under the headliner
coralman is offline
post #13 of 17 Old 10-05-2013, 07:28 PM
V65Ozzie
Pulled the console today, and found the wiring tucked up there. Auto mirror now installed.
Thanks
V65Ozzie is offline
post #14 of 17 Old 10-05-2013, 07:51 PM Thread Starter
MrSpooky
UPDATE: for future searches I replaced the mirror for a junkyard unit and it works. All the Grand Cherokees has their mirrors already taken but I did find the same one in a Durango.
MrSpooky is offline
post #15 of 17 Old 10-05-2013, 08:05 PM
xcaliber81
Ozzie, do you have the overhead console? Chances are if you had the wiring for the auto dim mirror you'll have wiring for the overhead console as well.
