Auto climate control - JeepForum.com
post #1 of 5 Old 04-03-2009, 04:42 PM Thread Starter
tapuout2
Ok did a search and found nothing. My auto climate control does not have any power to it so it wont work. I have already checked the fuses. I am going to remove it tomm. but was wondering if there is anything I should also check. Thanks for any response.
tapuout2 is offline
post #2 of 5 Old 04-03-2009, 05:58 PM Thread Starter
tapuout2
Does anyone know what the problem is checked the plug on back and it is plugged in. Can the control unit just go?
tapuout2 is offline
post #3 of 5 Old 04-04-2009, 11:25 AM Thread Starter
tapuout2
bump bump bump
tapuout2 is offline
post #4 of 5 Old 04-04-2009, 11:50 AM
alexsious
its electronic, of course it can die. there could be problems inside of it. once you have traced all the wiring to the fuses and relays, then try replacing it.
alexsious is offline
post #5 of 5 Old 04-08-2009, 06:38 PM Thread Starter
tapuout2
My buddy who owns a garage found the problem. Apparently the old owner drove a screw in to the fuse box and messed up the ATC, heated seats, and the abs circuits. Going to the junk yard they have a couple 1996-1998 that I can take from. Also if you need a good jeep mech. in MA this guy is great use to work at stealership in mid to late 90s and cheap hourly rate to boot.
tapuout2 is offline
Auto climate control fan ? reoj WK Grand Cherokee & XK Commander Forum 3 12-23-2009 07:25 AM
auto climate control shuts off merkur92 ZJ Grand Cherokee Forum 0 01-25-2008 07:58 AM
Auto Climate Control system 2Screwed ZJ Grand Cherokee Forum 5 12-19-2006 12:46 PM
2001 auto climate control dav717 ZJ Grand Cherokee Forum 1 10-15-2006 10:59 AM
