Audiophile expert - JeepForum.com
post #1 of 8 Old 05-29-2013, 01:31 PM Thread Starter
dusterdude
Audiophile expert
Im installing a brand new delphi x250 mp3 radio im the jeep.it has a weird pigtail that plugs into the radio and is supposed to adapt to the vehicle wiring.im buying an adapter harness for the zj wiring but as you can see,im not sure how the double ended plug on the radio harness is supposed to wire up to th zj
dusterdude is offline
post #2 of 8 Old 05-29-2013, 04:18 PM
ShinyWJ
So the wire harness for the new radio has a connector on each end? I'm seeing butt terminals on the one in the picture. You'll probably just have to cut one of the plugs off and wire it up to a wire harness that connects to the Jeep's factory wiring. Ya know?
Walmart sells the harness, you should be able to find one. If you've got the factory Infinity stereo in your ZJ don't worry about buying one that will bypass the factory amp- just get the regular harness and wire it up using the factory amplifier.
ShinyWJ is offline
post #3 of 8 Old 05-29-2013, 04:40 PM Thread Starter
dusterdude
Its looking like thats what im gonna do,thanks
post #4 of 8 Old 05-30-2013, 04:23 AM
ejschultz
ejschultz's Avatar
IIRC, if you have the factory amp, you have to hook up the "power antenna" on the Jeep side to the remote turn on from the amp. The "power antenna" on the Jeep side is the remote turn on. At least I had to do that when I had my HU in before I swapped everything out.
ejschultz is offline
post #5 of 8 Old 05-31-2013, 09:39 AM Thread Starter
dusterdude
Thanks ej,one more thing,there is a lone black wire that plugs into the back of the unit,any idea what that is for?
post #6 of 8 Old 05-31-2013, 10:37 AM
ejschultz
ejschultz's Avatar
It's a ground if I recall correctly.
post #7 of 8 Old 06-03-2013, 06:03 PM Thread Starter
dusterdude
Got it installed,still have a memory issue with the radio not holding the preset stations,im done with it for now,worry about the niggly crap another time
post #8 of 8 Old 06-03-2013, 06:25 PM
ShinyWJ
Swap the red and yellow wires. That should clear up the issue.
ShinyWJ is offline
