Audio Help! - JeepForum.com
post #1 of 12 Old 06-28-2013, 05:21 PM Thread Starter
RaevynCarrion
Could somebody please get me the wiring harness diagram for a 96 ZJ stereo connector?
RaevynCarrion is offline
post #2 of 12 Old 06-28-2013, 10:46 PM
ZeeJay1997
Infinity?
ZeeJay1997 is offline
post #3 of 12 Old 06-28-2013, 10:53 PM
ZeeJay1997
i think they are all the same.
sorry, website wont upload files, doing maintenance.
post #4 of 12 Old 06-29-2013, 04:23 AM Thread Starter
RaevynCarrion
I don't know if it ever had the Infinity, I bought it used with a custom job installed. But the factory wiring harness is still there.
post #5 of 12 Old 06-29-2013, 01:11 PM
chalkboard
I have been working on the oem radio in my '97. I googled for a schematic and was unable to find one exactly like mine (non-infinity.) What I did find after much reading is that though the pin locations found in many diagrams didn't match my harness plugs, the color codes are fairly consistent. I used a meter to check for resistance (4 ohms, I believe) to find speaker pin locations and test wiring for shorts, easier than chasing wires. I have forgotten whether it is the front or the rear, but one pair has the positive lead in one plug and the negative in the other.
I, too, would like to have an actual schematic for my non-infinity setup.
2001 WJ 4.7/73k "Old Bones"
1997 ZJ 4.0/154k Sold
chalkboard is offline
post #6 of 12 Old 06-29-2013, 02:51 PM
greyhnd
Go here.......www.installdr.com. Just do a search for your model and you'll find detailed write ups for installation and wiring. Many people here have used that site for help.
greyhnd is offline
post #7 of 12 Old 06-30-2013, 07:56 AM Thread Starter
RaevynCarrion
Thanks for the advice, everyone. I ended up doing a search on JF and found the right image for my ZJ. It turns out I blew out a bass block in one of my crossovers, so I had to disconnect my tweeters. Sacrificed my high end, butt least I can listen to music now.
post #8 of 12 Old 06-30-2013, 05:24 PM
Jenglish
Yea nothing like the popping when the infinity's are blown.
Jenglish is offline
post #9 of 12 Old 06-30-2013, 05:27 PM
ngould1
ngould1 is offline
post #10 of 12 Old 07-07-2013, 05:30 AM Thread Starter
RaevynCarrion
That definitely helped, but unfortunately since locating the problem I've corrected it and bought new crossovers...I apparently blew mine out some how. However, the same issue popped up, and I apparently can't run tweeters through my driver side door. Is there a wire connection for tweeters under the forward/top dash panel where it looks like you're meant to mount them in those empty vents? I may try wiring through there before I give up entirely.
post #11 of 12 Old 07-07-2013, 08:06 AM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Name:  radio premium.jpg
If you originally had the base system the wires should be under the panel unless the previous owner did something with them on the new system install. Unfortunately, even if there they dead end into the connector block adjacent to the BCM. Connectors C351 and C307 as seen in the diagram. They are parralell{?} to the full size speakers.
Since the new install of the system before you bought it it will be difficult to troubleshoot from here. Sounds like almost that the system is pumping too much power and blowing the crossovers. But thats just a guess.In my laredo I just ran two wires parralell to each door spreaker at the radio to supply the instument panel speakers.
The upper pic is of a base system without a amp.
Originally Posted by HighLonesome
coralman is offline
post #12 of 12 Old 08-22-2013, 06:43 PM Thread Starter
RaevynCarrion
Got it all figured out guys, thanks for the help. The issue was being cause by a feedback loop due to the tweeters in my 2-way door speakers. Ripped em out and stuck some 300W Pyle mids in the front door, whole new Pyle component setup in the back, and she's all good. Sounds ten times better, too.
