Attn Jeep Techs Loud cracking/ poping noise from front axle - JeepForum.com
post #1 of 9 Old 11-13-2008, 09:24 AM Thread Starter
nicecj7
My 1999 Wj V8 w/ Quadra Drive has a issue where during the rain or in the snow, or when cold or under tight turns into parking lots I get this loud clunk/ cracking noise from the front axle. It kinda sounds like my axle is snapping repeatedly. Its real loud but everything drives fine. I dont experience it under normal driving conditions (unless making tight turns into a parking spot). I replaced the fluids in my diffs and transfer case w/ the appropriate fluid , my cv joints are new . It will go into low range and drive fine unless i gas it causing the noise.
Any ideas on how to fix this? Is it my transfercase ? or a vari loc crapping out?
nicecj7 is offline
post #2 of 9 Old 11-13-2008, 09:35 AM
FPKites
ZJjazzyJim
FPKites's Avatar
Are you sure you got the QD axle shafts? There's a difference between QD and non QD shafts IIRC.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #3 of 9 Old 11-13-2008, 03:25 PM Thread Starter
nicecj7
yeah i did, i made sure when i ordered them that they were quadra drive axles .I had this prob before i installed the shafts and i thought it might be the cv joints but it wasnt .
1999 Grand Cherokee 4.7, Qudra Drive , Kolak 3" exhaust , K&N intake, Addco rear sway bar,upgraded calipers w/ Bembo Rotors and 18x9 Moda R6 rims
1999 mustang cobra
1988 mustang w/EFI 393w sold!
nicecj7 is offline
post #4 of 9 Old 11-13-2008, 03:27 PM
-Joe-
-Joe-'s Avatar
Is it only when moving?
Ex had a 99 that the power steering pump would go pop pop pop pop over and over when making turns. It eventually got a new pump.
- Joe -
'95 Jeep Grand Cherokee Laredo I6 4.0L
242TC - Extreme Engineering 2" Front Lift/1.75" Rear Lift - ES9000 Shocks + JKS BPEs
Moog Cargo Control Springs
Magnaflow Converter - Dynomax Muffler
235/75/15 AT Uniroyal Liberator Tires
-Joe- is offline
post #5 of 9 Old 11-18-2008, 09:18 PM Thread Starter
nicecj7
yeah its only when moving when there is any sort of power put to the drivetrain..
1999 mustang cobra
nicecj7 is offline
post #6 of 9 Old 11-18-2008, 09:20 PM
SplitNail
i know my t-case made a bad sound when pushing it really hard. it was the chain slipping.
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #7 of 9 Old 11-19-2008, 09:26 AM
Basscrazy51
The same thing happened in my friends jeep, it turned out to be what was called i think turning "boots"..
1993 ZJ I6 4.0 stock..
Basscrazy51 is offline
post #8 of 9 Old 11-19-2008, 10:09 AM
Double E
Double E's Avatar
Bass is referring to the CV joints (Constant Velocity). Funny, I have th same thing happening. Been going on for nearly a year and I replaced the CV joints (axles) in 05. It was done by the dealer.
The idea that it is the PS pump is interesting... I also have excessive wear on the outside of each tire. I'm wondering if that's related or if it's just an alignment issue...
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #9 of 9 Old 11-23-2008, 10:44 PM
LTD 318ZJ
More than other manufacturers; Chrysler vehicles make terrible noises from the front end when any kind of sway bar issues are apparent. Whether it'd be worn bushings, broken end links, broken bar or even loose end links (at the fastener or in the ball socket). Check all of these.
I recently serviced an 07 Town and Country with 20k miles on it. Making ridiculous popping noises and the solution was new sway bar bushings. Completely different breed but my zj makes similar noise when I break end links and when I had worn bushings.
LTD 318ZJ is offline
Have a loud hum/vibration noise coming from the front axle area. 3rdgenfan ZJ Grand Cherokee Forum 9 04-22-2012 11:29 PM
Axle/wheels make loud knocking noise on sharp turns Gracie ZJ Grand Cherokee Forum 10 01-22-2011 09:06 AM
99 jeep GRAND CHEROKEE! CRACKING NOISE BEHIND DASH xowiickedox ZJ Grand Cherokee Forum 4 06-02-2009 11:58 PM
loud cracking sound dirtdogg ZJ Grand Cherokee Forum 7 04-29-2009 09:31 PM
98 Grand Cher. Cracking noise in front end craigndee ZJ Grand Cherokee Forum 4 09-30-2007 09:14 AM
