ATTN all 5.9ers - JeepForum.com
post #1 of 19 Old 08-29-2012, 05:58 AM Thread Starter
theopacific1
ATTN all 5.9ers
this is my second 5.9 where it seams like the rear diff is howling. or at least its a lot of road noise. if you have ever heard the noise of your brakes rubbing when you use them, its that sound but inside the rear of my zj. and its not my brakes. need opinions asap!!
theopacific1 is offline
post #2 of 19 Old 08-29-2012, 06:27 AM
Dyn0mitemat
Let me introduce you to the d44a
edit:
Its the pinion bearings, its a very common problem with those rear ends
09 Rubi 2dr:MetalCloak2.5", 37"MTZ's/Slabs, EVO Stff, ORFab Cage, Chromo's, Driveshafts etc
Dyn0mitemat is offline
post #3 of 19 Old 08-29-2012, 06:27 AM
newfieZJ
Bad pinion bearings or bad carrier bearings most likely . Some have descibed it as the sound of a jet plane
1995 Orvis build
1988 MJ build
1998 Slate 5.9 build
1998 Platinum 5.9 build
newfieZJ is offline
post #4 of 19 Old 08-29-2012, 08:19 AM
frankcougar
I have owned three 5.9's. Two of them have had that sound you're describing. It's common.
1998 ZJ 5.9 Limited White 187,XXX miles
1998 ZJ 5.9 Limited Slate 148,XXX miles "Sucker Punch"
frankcougar is offline
post #5 of 19 Old 08-29-2012, 11:43 AM
MN59ZJ
Yep, what they all said. The best cure for it is an 8.8.
MN59ZJ is offline
post #6 of 19 Old 08-29-2012, 11:50 AM
PolkaPower
Mine was the carrier bearings and the washers from the limited slip coming apart. Total cost for rebuilding the limited slip, replacing the carrier bearings, and fill it with new fluid was 700 bucks from a reputable shop in town. Labor was why is cost so much.
PolkaPower is online now
post #7 of 19 Old 08-29-2012, 06:13 PM
Technohead
Its expected on a vehicle that is 15 years old.
-Eric
Technohead is offline
post #8 of 19 Old 08-29-2012, 09:46 PM Thread Starter
theopacific1
it was one of my pinions. it was starting to chew up the brings. THANK YOU EVERYONE!!!
post #9 of 19 Old 08-30-2012, 01:50 AM
uwhawkman
What did it cost to repair if you don't mind me asking?
uwhawkman is offline
post #10 of 19 Old 09-13-2012, 11:48 PM Thread Starter
theopacific1
im good friends with my mechanic. little over 700 and he only charged me for 2 hours when it was up on his lift for 3 days....
post #11 of 19 Old 09-14-2012, 09:25 AM
MN59ZJ
I only paid $600 for my 8.8 conversion.
MN59ZJ is offline
post #12 of 19 Old 09-14-2012, 09:45 AM
Timo_90xj
Timo_90xj's Avatar
D44a is a really crappy design for the ZJs and WJs, that's why they don't last long enough like an axle should. I understand wheel bearings go bad a couple times over 15 years and 100-200k miles, but not pinion or carrier bearings..
I've seen as new as few years old, well under 100k D44As with bad bearings, that's not something what should happen on a high quality axle (what the D44a is not in its solid axle version)
***Under construction***
Timo_90xj is online now
post #13 of 19 Old 09-14-2012, 10:53 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
I've seen the d35 do the same things and same with the d30.
I've also seen d60s with carrier bearings spun in the bore with less than 50k.
You should see the life expectancy of those exact same bearings in the cnc equipment i repair. a few months is pushing it in some areas that don't even see harsh conditions or high speeds.
ratmonkey is offline
post #14 of 19 Old 09-14-2012, 11:42 AM
Cdy291
From what I heard the reason the carrier bearings go bad in the Dana44a is because the axle tubes were pressed in with 30 tons for force after the gears and bearings were installed that the factory. This deformed the shape of the Aluminum differential and over loaded the bearings.
All I did with my 44a was replace one carrier bearing, for $15 (timken), problem solved.
Cdy291 is offline
post #15 of 19 Old 09-14-2012, 10:30 PM
DigitalPhoenix
My front end did the same thing, bad bearings. Only paid $110.00 to do it by me and some of my buddies.
5.9 ZJ bone stock.
If it ain't broke, fix it til it is.
DigitalPhoenix is offline
465 HP 6.4 Hemi SRT8 in a '96 ZJ Laredo 4x4?!? Eat your heart out 5.9ers!! (pix) reydelaplaya ZJ Grand Cherokee Forum 10 06-25-2011 09:52 PM
ATTN: nor cal WK'ers tednelson83 WK Grand Cherokee & XK Commander Forum 1 10-20-2008 12:08 AM
Attn: NewB's KingPrat WK Grand Cherokee & XK Commander Forum 1 11-10-2006 10:44 AM
ATTN: JosephMartins PumaZJ ZJ Grand Cherokee Forum 13 03-23-2005 04:51 PM
Attn: K-Pax SkyjacktZJ ZJ Grand Cherokee Forum 2 12-27-2004 06:24 PM
