ATF poring out between TC and trans. Output shaft seal? - JeepForum.com
post #1 of 10 Old 09-22-2013, 04:16 PM Thread Starter
Sickws6
I'm loosing a lot of fluid where the transfer case flange mounts to the transmission housing. Wondering what it could be and what is involved. I'll tear it down soon after I get some suggestions. Thanks!
1995 JEEP YJ
2001 AUDI A4
2004 discovery II
2001 ws6 trans am
Sickws6 is offline
post #2 of 10 Old 09-22-2013, 04:30 PM
shaban
Must be either tranny output seal or tcase input seal, I think.
Tcase is pretty easy once you get it out, havent done the tranny but I'd imagne you'd have to do it from underneath.
shaban is offline
post #3 of 10 Old 09-22-2013, 04:46 PM
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
It's probably the rear trans seal. TC must come out, not too bad of a job tho.
HighLonesome is offline
post #4 of 10 Old 09-23-2013, 12:19 AM
D-rey
I had the same problem. My trans output seal was puking fluid. Since the t-case has to come out anyway, I replaced the input seal (t-case) as well.
D-rey is offline
post #5 of 10 Old 09-23-2013, 12:28 AM
98GCLimited
Yup common failure. My ZJ was leaking from there as well. Its probably the transmission output seal. Might as well do that and the transfer case input seal since you need to remove the transfer case to get to the seal.
Drain your transfer case fluid. Then you are going to need to unbolt the front driveshaft at the transfer case I think its 4 8mm bolts and the rear driveshaft 4 8mm bolts at the rear axle. Might need to use a big screwdriver or pry bar to break the driveshafts loose at the unbolted joints they shouldnt be stuck too bad just a little persuasion. Put a jack with a piece of wood under your transmission and jack it up to where its up to the pan level to hold it in place when you remove the crossmember. Then unbolt the transmission mount to crossmember bolts its 4 bolts in the center of the cross beam under your transfercase/transmission. Then unbolt the crossmember from the frame rails 2 bolts on each side.
Unplug your two wiring connectors on the transfer case and disconnect the vent hose on the transfer case. You can now slightly lower the transmission down by lowering the jack a few inches, this helps greatly to access the top two nuts especially the top passenger side is the tightest to get at. I highly recommend a small or short length stubby 9/16" box end wrench for the top two nuts that connect the transfer case to the transmission. I found the stubby 9/16" 12 point box combo wrench at Lowes for like $8 or whatever, well worth the cost. A regular length 9/16" box end wrench works fine for the other 4 nuts (there are 6 total). You can then return the transmission to its original position or there about by jacking the jack back up a couple inches this helps keep less transmission fluid leaking from the rear of the tranny when you pull the transfer case off the back end. Be prepared for some to come out anyway so put a pan underneath to catch the fluid. Then pull/slide the transfer case back away from the transmission and it will slide off the transmission output shaft. Careful depending on what transfer case you have it could be decently heavy. Id say my 249 case was a solid 80lbs or more and my 231 was noticeably lighter just be prepared for a little weight.
You should now be able to see what looks like in the above picture and remove and replace that seal and the one on the front of the transfer case too while you are at it.
98GCLimited is offline
post #6 of 10 Old 09-23-2013, 08:36 AM
dnuccio
Id say the 249 is around 120 pounds. I've got one sitting in my garage I'll weigh when I get home. 242 and 231 are at least 30 pounds lighter I think
Reliability is relative
R.I.P. Ratmonkey
dnuccio is offline
post #7 of 10 Old 09-23-2013, 10:38 AM Thread Starter
Sickws6
you guys are great! Great information here!
1995 JEEP YJ
2001 AUDI A4
2004 discovery II
2001 ws6 trans am
Sickws6 is offline
post #8 of 10 Old 06-29-2016, 08:16 PM
Hassel2
Old thread, but having the same issue and I was wondering what gaskets/seals to get? It's a jungle out there and I figured you guys know
http://www.ebay.com/itm/Seal-4wd-Ada...NSvdof&vxp=mtr
Would this be the correct one?
Hassel2 is offline
post #9 of 10 Old 06-30-2016, 10:14 PM
paulsheer2
See www.showmetheparts.com/timken/ for part numbers.
I think Timken has a good reputation *shrug*
rockauto.com has the widest selection.
93 ZJ 5.2, 3.58 stroked. 242 swap. 2.5" lift. dozens of mods.
paulsheer2 is offline
post #10 of 10 Old 02-14-2017, 04:28 PM
tetatdo
1994 ZJ
OP, I know this is an old thread, but when you had the issue with the leak between the trans and TC, was the leak going down in between the trans/tc or did it flow down to the lowest bolt on the TC and drop from there?
i'm losing a crapload of fluid but I cant tell if it's the TC or the trans or something else...
Tetatdo
94 ZJ 4.0L/NV242 WJ Manifold, 63mm TB, Kolak 2.5" Exhaust, 703 Injectors, SBEC-II Tune
tetatdo is offline
