ASD relay...what triggers it. - JeepForum.com
post #1 of 11 Old 11-06-2007, 04:53 PM Thread Starter
whitejeep96zj
So my jeep has just started to die randomly all of the sudden. I thought it was fuel so i gauged it and it stays at 48 psi all the time. I have used voltmeters on all the sensors and they are all in the right range. So i was wondering what triggers the asd relay to kill the car because i was told when i got it that the security system has triggered it a couple of times even though the car was unlocked using the key. Thanks.
1996 ZJ 4.0 L with 255k
whitejeep96zj is offline
post #2 of 11 Old 11-06-2007, 05:16 PM
greasefingers
greasefingers's Avatar
1994 ZJ
Sounds to me the security system may be suspect?
The computer (ecu or pcm) triggers the relays by grounding them
Electrical trouble-shooting can be a biotch. I have spent several cold winter nights on my back under cars with flood lights and propane heaters. Hint: you need a stock of hot chocolate and a warm women waiting inside your house!
If you test the circuit for battery with the key in the On/Run position; then you only have about 3 seconds before the PCM times out. This is because the PCM needs a Cam & Crank shaft signal. If it does not see these then it de-energizes the ADS relay (automatic shutdown relay). The ADS relays powers the fuel pump relay. The relays will make a clunk when energized. However this is not true when power is removed from them! They have a soft return. I place a finger on each the two relays when I want to see if power is getting to them. That way you are fooled by other neighbouring relays in there.
Cheers Steve
94 Black Laredo 4-Liter with QuadraTrac (42RE trans & NP249 TC) 200,000 + miles purchased new
88 Cherokee 2-door with 5speed manual 139K miles(deceased) purchased new
greasefingers is offline
post #3 of 11 Old 11-06-2007, 07:32 PM Thread Starter
whitejeep96zj
well what would happen if i put a jumper in the place of the relay? Would that cause any harm to any of the other electrical systems? im not sure if its that relay or not cause the car will drop to 0 rpms for like half and second and then bring it back to life on its own. I have spent all day looking for a suspicious sensor and im about to call it quits.
post #4 of 11 Old 11-09-2007, 11:20 AM
greasefingers
1994 ZJ
If you suspect it is a relay then swap it out with one of the same type. Most of the relays in the relay center are all the same so choice one like from the A/C or fog lights (something you can live without, but just for trouble-shooting) The relays are $ 9 at the dealership
Cheers Steve
post #5 of 11 Old 11-09-2007, 11:33 AM
t_guenther
I disabled my security system, seemed to have fixed a few problems, including vehicle shutdown, and walking into a store only to have to walk all the way back to my truck to stop the horn from honking. Not a good system at all, if you need a system, buy a viper or something reliable.
Michigan Tech. Univ. - MET, Senior
--95 Grand Cherokee 5.2L V8--
Front/Rear Adj. Track Bar, 249 to 231 Swap, Tie rod conversion,
Hella 500's, Flowmaster 50 Series, Aussie Locker in the Rear,
31x10.5 BFG All-Terrains on 15x8 Pro Comp 97 Crawlers, 3" Lift
t_guenther is offline
post #6 of 11 Old 11-25-2007, 06:27 PM
wkobe88822
so how did you disable the security system? and one more question is the oil level light and idiot light or is it a system shut down light because i have changed the motor and the replacement motor has no where to plug the oil level sensor in
wayne
wkobe88822 is offline
post #7 of 11 Old 11-25-2007, 06:33 PM
t_guenther
Well, if you take your door panel off and find the wires going to the sensor in the door, there will be one that is purple with a yellow stripe. Cut it and ground the wire, i can't remember off and what side of the wire you need to ground, but just do a search like security system disable or something like that and you will get quite a few threads that explain how to do it. I have no idea about the oil thing.
post #8 of 11 Old 04-07-2013, 06:06 PM
nleana77
1995 FSJ Cherokee
i have similar issue...
just got a 95 jeep grand cheerokee, nothing even starts...inside car lights are just on...
bought new battery bcus it made a clicking noise...but now engine turns over but doesnt crank or start so to say..
a/c comes on but not the radio..headlights nor signals dont even work..can't lock the doors...wth do i do?
nleana77 is offline
post #9 of 11 Old 11-19-2014, 05:22 AM
shawtyNziggy
I have a 1998 4.7ltr jeep grand Cherokee Laredo, I just purchased it for pretty cheap but upon purchase it was covered from top to bottom in mud and driving it home it wouldn't stay at idle unless I kept my foot on the brake and accelerator at the same time or toggling between the two but always had to keep foot pressed on accelerator or it would die, so I cleaned it up and after reading possible diagnosis to my problem, I tried cleaning the connections to and from ecm and relays and made sure hoses were securely connected, now vehicle will idle on its own just sounds a bit rough, but dies out when I push the accelerator to go...anyone have any other suggestions? o ya also the gas cap wasn't on it when I bought it
shawtyNziggy is offline
post #10 of 11 Old 11-19-2014, 05:59 AM
Kingr98
2016 JK Wrangler
Are you sure it is a 1998 GC? Remember that the Jeeps built late in 1998 are actually 99 models. The reason I ask is because Jeep did not make a 4.7L GC in 1998. I think you might have a 1999 WJ.
That being said, have your battery checked. If your 4.7L is anything like my 4.0, it is highly sensitive to a bad battery. Your description of how you had to drive it is exactly what I went through before I replaced the battery.
Kingr98 is offline
post #11 of 11 Old 07-17-2015, 11:37 AM
steeltrilogy
pcm problems
hi I know this is an old post but I was having problems with my Jeep 01 Grand Cherokee 4.0 I was having problems with it for the last week speedometer would spike all the lights would shut off and come on the vehicle would shut off for a few seconds and then turn it back on without touching the key finally the other day I was driving down the street and everything just shut off on me I've looked at over a hundred forums and every single one of them said something about it could be your PCM ECM crankshaft position sensor battery alternator I even heard one guy say it might be the catalytic converter which you know is crap. so somebody at work told me to check the fuses so I started checking all the fuses and what not and up until this point I had absolutely no power at all so I pull the fuse out and replaced it with the one right next to it because they look the same they were the exact same fuse anyway so right when I pulled the fuse out my hood light came on so I put the fuse back in the hood light goes off I play with the fuses a little bit and It came back on and i ran over to my ignition and tried starting it and nothing, now at this point I'm really thinking its computer and I'm about to buy a new one I touch the leads that are going into the fuse box underneath the hood one of them is not making contact so all you guys out there thinking it's your computer make sure you test it even if its loose the plastic it's being held to it might have burn through it already easiest way to get this off to take a Dremel and cut it straight down the middle cutting through the screw or the bolt and the nuts holding it on take it out from the bottom put a brand new bolt in there with a nut holding it in and a nut over the top connecting to the metal plate. this worked and everything started right back up and I'm about to take it for a drive
steeltrilogy is offline
ABS relay 4x4JeepinZj ZJ Grand Cherokee Forum 8 07-15-2013 08:40 PM
Please help fan relay???? sawyer1 WK Grand Cherokee & XK Commander Forum 3 03-01-2009 09:21 AM
e-fan relay BLACKzj52 ZJ Grand Cherokee Forum 19 08-28-2007 10:46 PM
Which relay did i fry? noreaga0221 ZJ Grand Cherokee Forum 7 07-04-2005 03:18 PM
radiator relay and fuel pump relay nobleicon ZJ Grand Cherokee Forum 0 06-11-2002 02:18 PM
