Arc welding on a unibody - JeepForum.com
post #1 of 19 Old 10-04-2009, 08:56 PM Thread Starter
JakeDS
I'm in the process of finally setting up a welder to install my Clayton's kit. He seems very knowledgeable and confident, and swears that ARC welding is the way to go. This seems to contradict what everyone on the forums is doing, as well as the pdf instructions for the kit. Thoughts? Comments? My brother welds a lot, and says that he doesn't see a problem with it, but I'd like some info from somebody who knows the Jeep unibody specifically.
Right you are, Ken.
JakeDS is offline
post #2 of 19 Old 10-04-2009, 09:03 PM
Kenbo-Slice
Seems that ARC welding would be a pain in the *** to do on a unibody.... They aren't all that thick but it could be done with no problem. Use the correct electrode for the steel you're working on. I usually only stick weld THICK steel, using multiple passes. I have done thick sheet metal with it though when I was in my welding class.
Jeep build up...ONGOING
Kenbo-Slice is offline
post #3 of 19 Old 10-04-2009, 10:02 PM
FortCollinsZJ
Does he own a mig?
FortCollinsZJ is offline
post #4 of 19 Old 10-04-2009, 10:08 PM
redhatman
redhatman's Avatar
I would use an industrial wirefeed for that, seems the easiest to control in that position. With the unibody you are supposed to stich weld, that way there is not too much heat buildup that would warp the metal.
-Pat
I am now a dealer for Iron Rock Off Road
I offer the same great products you already know about,
the same low prices you have been seeing, and with
the same experienced customer support, but I can offer it nearly 24/7
5.9 ZJ 7" IRO, 35s, 8.8, hp30, locked, blah blah
Originally Posted by CMARJEEP View Post
Those tires look freakin awesome Redhat... took the ZJ up a notch in my book. Now you're at notch 2.
redhatman is offline
post #5 of 19 Old 10-04-2009, 10:19 PM Thread Starter
JakeDS
Originally Posted by FortCollinsZJ View Post
Does he own a mig?
Yeah, he owns a mig, so, I would think that he would use that if he thought it was best. Seems like I'm getting mixed opinions. One argument, "What do you think was used before mig welders came about?"
Right you are, Ken.
JakeDS is offline
post #6 of 19 Old 10-04-2009, 10:24 PM
redhatman
redhatman's Avatar
Its not really an argument, its more about which is better today.
-Pat
post #7 of 19 Old 10-04-2009, 10:28 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Stick welding sheet metal upside down is about the most difficult thing you can do in a garage. No way would I do it with a mig available.
Sounds like someone who doesn't know how to use a mig very well to me.
ratmonkey is offline
post #8 of 19 Old 10-04-2009, 10:30 PM
BigDaveZJ
The stick will do it, the MIG will be easier.
95 ZJ with lots of stuff
14 WK2
BigDaveZJ is offline
post #9 of 19 Old 10-04-2009, 10:38 PM
redhatman
redhatman's Avatar
Well said.
-Pat
post #10 of 19 Old 10-04-2009, 10:42 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
Just mig it. Waayy easier for the position.
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #11 of 19 Old 10-04-2009, 11:26 PM
Virmagicus
Virmagicus's Avatar
If you want to drive down the road and your Jeep split in quarters arc weld it FTW.
Jeff
Virmagicus is offline
post #12 of 19 Old 10-04-2009, 11:33 PM
CLNinja
CLNinja's Avatar
MIG weld it and read this
Unibody Welding Bible - MallCrawlin.com Forums
Matt
**September 2009 Grand Cherokee Of The Month**
CLNinja is offline
post #13 of 19 Old 10-05-2009, 07:23 AM
IslandManMitch
Before mig welders there were no unibodies.
If he is a competent ARC welder he can weld on the unibody. I would just make dang sure he is competent before he welded on mine.
IslandManMitch is offline
post #14 of 19 Old 10-05-2009, 07:54 AM
Area.3.Fiftyone
I thought they only used arc welding for 3/4" (or more) steel plate at ship yards? The Uni Body is only about 1/16" thick and he will burn right through it.
Seriously: IF you are going to weld them on use the MIG.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #15 of 19 Old 10-05-2009, 08:08 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
i've seen mig welders that will do one pass on 2" plate and i've arc welded body panels before. no one method is exclusive to any purpose.
personally i'd rather tig the mounts into place.
Welding to the unibody shdybrady19 ZJ Grand Cherokee Forum 6 02-01-2010 10:39 AM
Welding to the unibody shdybrady19 ZJ Grand Cherokee Forum 6 04-29-2009 10:54 PM
welding to the unibody? illegal? Ds4x4 ZJ Grand Cherokee Forum 46 01-03-2008 06:45 PM
Welding V.S. Bolting to a unibody! Example: Rock Rails Opinions & Tips? Hints?? Polaris Junkie ZJ Grand Cherokee Forum 23 09-16-2006 10:31 PM
Unibody? wnttodrve ZJ Grand Cherokee Forum 11 11-18-2005 11:35 PM
