Anyone try AC Pro on their ZJ? - JeepForum.com
post #1 of 11 Old 06-19-2012, 01:06 AM Thread Starter
sbxj
sbxj's Avatar
Any problems or cautions? Success?
Thanks!
'01 XJ 2DR Sport
'99 WJ Laredo, 4.0L with HID Retrofit
sbxj is offline
post #2 of 11 Old 06-19-2012, 01:09 AM
az93cherokee
I actually just tried it yesterday and unfortunately my ac is still hot the ac pump kicks on now but thats about it but might be somthing eles wrong with mine
Sent From Under The Hood Of A ZJ
az93cherokee is offline
post #3 of 11 Old 06-19-2012, 01:13 AM Thread Starter
sbxj
sbxj's Avatar
Thanks for the reply.
Was it blowing any cold air at all before the recharge?
'01 XJ 2DR Sport
sbxj is offline
post #4 of 11 Old 06-19-2012, 01:27 AM
az93cherokee
Yeah last summer it was kinda cold now nothing
post #5 of 11 Old 06-19-2012, 01:55 AM
mr4x4
You should have it sucked down to make sure there's no air in the system those ac recharged kits are really only for a top off if the system got a little low not completely gone
If there's a leak the vacuum won't hold and bring the system where it needs to be and should be fixed
If done correctly and no leaks the ac will get very cold
94 stock zj and a 95 zj with a 5.5" lift with 35" bfg km2 a rear currie 9in with 4.56 gears an arb and 35spine axle shafts and 4.56 gears in the front Hp30 super30 kit arb 4.1 low range transfercase
mr4x4 is offline
post #6 of 11 Old 06-19-2012, 10:30 AM
Marcos
Looking on their websites, it seems to be a mix of products that aren't really new to the market:
Refrigerant
Oil
Stop leak
drying agent
PROA (Polarized refrigerant oil additive) - claimed to boost system efficiency and performance.
In short, trying to be a fix-all in a can.
Marcos is offline
post #7 of 11 Old 06-19-2012, 10:49 AM
chich
I used it on mine a couple of weeks ago with good results.Was blowing warm before,and now it's nice and cold.
chich is offline
post #8 of 11 Old 06-19-2012, 08:02 PM
savannahzj
Mine had a slow leak. Instead of trying to find the leak, I decided to try A/C pro. It has seemed to stop the leak. Been 2 months, where before it would last 2 weeks. so I would say try it if it holds a charge for any decent amount of time during which it blows cold.
savannahzj is offline
post #9 of 11 Old 06-19-2012, 08:23 PM
RazorbackZJ
1994 ZJ
I used it about a month ago seems to have worked. Still not ice cold tho. Better than hot air.
RazorbackZJ is offline
post #10 of 11 Old 06-19-2012, 08:30 PM
TheHalfWit
Maybe I'll try it then, mine will work for a month, maybe month and a half before needing another can.
Calm. C.
If a week goes by without needing to replace something, pinch me because I must be dreaming.
TheHalfWit is offline
post #11 of 11 Old 06-19-2012, 10:12 PM
Billyjoebob007
My system was totally discharged after installing a new full aluminum radiator and new ac condenser. Put in one can of the ac pro and it charged up my system to about the half way mark in the green on the gauge on the can. Been using the ac periodically for the past month and almost every day the past week and ac is blowing nice and cold. The hotter it is outside the more my system has to work to keep interior cool though, the past couple days have been 100 deg, after about 15 min of highway driving my engine temps start slowly climbing past the normal 210 deg mark. I guess thats the norm .
Billyjoebob007 is offline
