Anyone running stock 16" rims and 4.5" of lift? What size tires do you run? - JeepForum.com
post #1 of 6 Old 02-12-2007, 09:04 AM Thread Starter
bjl95mustang
bjl95mustang's Avatar
I am going to be installing my lift here soon and my tires are about worn out. I would like to keep the stock 16" limited rims.
What kind of rubbing issues would I have with some 285-75-16 tires? Would I beable to runs them with out spacers?
ZJ 98 5.2 LIMITED De-Badged
4.5" Lift: RE 4.5" springs,Iro rear 3.5 springs+1" spacer, RE shocks, All adjustable arms, IRO front track bar and HD bracket, Rear jks track bar, 1-Ton Steering, 242 tc, 33x12.5x15 GoodYear wrangler silent tires, 15" rock crawler rims, Aussie Locker For My 44A, 760X u-joint front axles.
Soon to come Lock Right Front Locker.
Jeep Inferno member #10
Texas Jeep Club Member #78
bjl95mustang is offline
post #2 of 6 Old 02-12-2007, 09:07 AM
nierace
nierace's Avatar
2003 WJ
You'll have pretty good rubbing and gearing issues if you go with that size...
Most guys run 33's on 6+
But if you do enough trimming you can take care of the rubbing problem. The gearing is pushing it with 33's on the stock 3.73's if you do all local it would probably be fine, but going up big hills on the highway is where it sucks.
For the rims you'll need spacers to put you at 3.75-4" back spacing for 33's
Nickerdoodle
03 WJ 4.7 242HD Kolak/IRO 5" Clayton LA's
35" BFGoodrich KM2
North East Offroad Club
nierace is offline
post #3 of 6 Old 02-12-2007, 09:07 AM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
I would run 265/75/16
Thats 32/10.5
the 285/75/16's are 33x11.5 and would rub A LOT!
2013 FR-S
BlaineWasHere is offline
post #4 of 6 Old 02-12-2007, 09:43 AM
MidniteSquirrel
I'm running the 2.5" BB from Kevin's and I also have 265/75R16's running on stock wheels. Have some nice rubbing issues on the control arms and limited my turning radius before I put 1.5" wheel spacers on. Keep in mind, those saying you need 3.75"-4" back spacing are thinking of the ZJ. But for a WJ, you start with 6" backspacing on the stock 16" wheels, 17" I believe has the 6.25" backspacing. Putting on anything more than a 1.5" wheel spacer is NOT recommended. Sort of like don't run a polypuck (BB) more than 2"-2.5"...
see www.wjjeeps.com for stock information if you need to.
Edit: Wanted to add that even after the 1.5" wheel spacers, I had to trim part of the front bumper to keep it from rubbing while turning and in reverse.
2002 WJ - I6
BB+UC 3.5" lift | K&N FIPK | Armor/Tow points |
265/75R16 Cooper Discoverer S/Ts
MidniteSquirrel is offline
post #5 of 6 Old 02-12-2007, 09:46 AM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
If you have ditched your stock LCA's for aftermarket LCA's, expect even more rubbing issues.
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #6 of 6 Old 02-12-2007, 12:23 PM
jeepsterbabe
Thats 32/10.5
thats what im running, works well...depending on how hardcore you are...if youre gonna start doing things like disconnecting sway bars and such then you'll need to trim more obvioulsy...
silly boys, trucks are for girls!
jeepsterbabe is offline
2.5" BB w/ stock rims and tires CMARJEEP ZJ Grand Cherokee Forum 22 08-19-2007 07:38 PM
Pics of WJ's on 15" rims 32+" size tires Clayton00grand ZJ Grand Cherokee Forum 1 02-22-2006 08:25 AM
3" lift, 285-75-16 stock limited rims, and 1"wheel spacer. Will it work? bjl95mustang ZJ Grand Cherokee Forum 1 01-26-2006 12:17 PM
Pics Wanted: WJ w/2" lift and stock size tires... BlaineWasHere ZJ Grand Cherokee Forum 11 03-13-2005 09:16 AM
max size tires for stock 02 grand cherokee 16" rims frankieve WJ Grand Cherokee Forum 4 01-20-2004 08:15 PM
