anyone put rear xj shocks on a zj? - JeepForum.com
post #1 of 6 Old 10-15-2010, 03:13 PM Thread Starter
customzj73
okay so i bent my mx6 monotube shocks on my last outing and i need two new rear shocks. im runnin 8" of lift and cant find any cheap shocks that big besides Rusty's cherokee shocks....
now i know that they are a softer spring rate but that doesnt really matter,
Will they fit??? i know the mounting is the same almost but i have heard that the mounts themselves are different??
93 ZJ V8 7.5" Rock Krawler X-factor kit w/ ACOS spacers and MX6 adjustable shocks,
ARB air locker up front, Lock Right in the rear
customzj73 is offline
post #2 of 6 Old 10-15-2010, 08:01 PM
TallyZJ
Don't think that works. XJ's use a bar pin up top and eye loop down below. You could remove the bar pin and insert a bushing sleeve but the length may not be right either.
ZJ's use loop eye bottom and top.
1996 Jeep Grand Cherokee Laredo 4x4 - 4.0L
TallyZJ is offline
post #3 of 6 Old 10-16-2010, 09:18 AM
StellaTheZJ
I did this on mine, running Rancho 9000s. Yes pins need to be removed etc, but it can be done if the length is OK. Cherokees use a longer shock for a given lift - quite a bit longer. So check the specs!
But talk to Rusty's. Whoever they buy from will likely supply them with ZJ shocks for the same prices, even if they are not in the catalog today.
Good luck!
StellaTheZJ is offline
post #4 of 6 Old 10-16-2010, 09:37 AM
FPKites
ZJjazzyJim
FPKites's Avatar
I'd go the special order route. Rusty's will work with you.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #5 of 6 Old 10-16-2010, 04:00 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
throwing unmatched shocks in the back will give you an aweful driving experience.
pony up for the same as the fronts.
ratmonkey is offline
post #6 of 6 Old 10-17-2010, 11:09 AM
StellaTheZJ
Having different shocks in the rear may be just fine - or not. Depends on the load you typically carry. I have adjustable shocks, and running empty, the front shocks are set firmer than the rear. On the other hand, towing a heavy trailer, or with a family full of bodies and gear, I set the rear shocks very firm. So if the rear shocks end up being different than the front, you might like them sometimes, and not so much at other times.
As ratmonkey says though, having all four shocks the same may give you the best experience under all load conditions.
looking for stiffer rear shocks, WK wingshooter2009 WK Grand Cherokee & XK Commander Forum 7 05-18-2010 04:20 PM
rear hatch shocks 97 ZJ Steve ZJ Grand Cherokee Forum 25 02-01-2010 04:25 PM
Will 265/70/16s rub the rear shocks??? Ctcharger ZJ Grand Cherokee Forum 5 12-13-2009 04:59 PM
Changing rear shocks... itasor WK Grand Cherokee & XK Commander Forum 2 06-12-2008 09:48 AM
HOW TO TAKE ZJ REAR SHOCKS OFF!!!!! Help CMARJEEP ZJ Grand Cherokee Forum 16 01-31-2008 04:21 PM
