#1 | |
Anyone every run 315/70-17's?
I have a buddy that is the service mgr at a Hummer dealer in So Cal. They quite often get takeoff wheels and tires (BFG AT's 315/70-17's) because of all the "bling" wheels those guys just gotta have on their highly capable off road mall crawlers!
Anyway, I can get a set of the tires (with wheels) for very cheap and they are all brand new. It's a pretty good deal and seeing how I'm probably going 35's anyway these would be a good match up. My ony questions is what wheels to run. I wanted to run black rock crawlers but they don't make 17's. I see a couple American Racing that have a black powder coat finish but don't know about back spacing. I can't think of any down side of running these tires, assuming I can get the correct wheels. I guess the Americans would reduce my unsprung weight over the steel ones. Any one running 17's on their ZJ's?
'95 ZJ 5.2 LTD, 3.5" RE + 2" pucks, 5.9 wheels with ProComp XTerrains 285/75-16, CV drive shaft, KOR sliderz, adj track bar (front & rear), skid plate, rad support, OME steering stabilizer, JKS adjustable LCAs & UCAs, MX6 shocks, 4.56's, OX Locker in front, Detroit locker with 30 spline axles in rear, Carbon fiber cowl induction hood, Adco's w/custom disco mounts, DOM tube tie rod & drag link w/spherical rod ends. '05 Avalanche 2500 4X4, 8.1/496, 4.10 gears, 6" CST lift, 315/70-17's on H2 rims. |
#2 |
Addicted to Boost.
If you can get the tires cheap enough to make it worth your while then get some nice 17" aluminum wheels and you will be good to go! I would get some nice agressive back spacing on them though... Maybe like 4" of B.S.
2007 VW GTI |
#3 |
Jeep Jedi Master
Okay,
I found you multiple Black "rockcrawler" type wheels in less than five minutes. You need to get off the couch and do some surfing. 1. www.americanracing.com look under Mojave and Chamber 2. www.4wheelparts.com has the Mojave Teflons on sale in the 17 x 8 inch size. 3. www.4wheelparts.com has Rock Crawlers in black in the Series 97 in the 17 x 9 inch rims for 79.00 each. Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns and 33 Bridgestone Duelers Detroit and true trac Red Jeep Club Member REDNECK JCM Texas Jeep Owner #6 USN Jeep Club #4 http://www.kevinsoffroad.com/ 602.841.3355 For your performance needs: kolak@kolakperformance.com 480.998.3661 |
#4 |
GSMW!
I thought hummers had a 16.5 inch wheel, not 17
-Tim GS-MW 2009 INFO KD8EBC '94 ZJ 5.2 LTD Project TORTOISE Build-up thread JCR Rock Sliders Ford Taurus E-fan Install Dana 20 Twin Stick |
#5 | |
Addicted to Boost.
H1's have a 16.5 H2's have a 17
2007 VW GTI |
#6 | |
GSMW!
Oh, thanks for clearing that up! ![]()
#7 | |
Addicted to Boost.
Tim... I am always there for you! ![]() And just for fun... ![]()
2007 VW GTI |
#8 |
JEEP FREAK
Another wheel option is Cragar Soft 8s.
17x8, 5 on 4.5, and 4.5" of backspacing. http://store.summitracing.com/partdetail.asp?part=crr-3978812
98 TJ |
#9 | |
Viewer Discretion Advised
#10 |
your gonna need a lottttt more lift if u plan on fitting those
#11 | |
I didn't see the 17" RC's though. I wonder how much weight difference there is between those and the Americans. Thanks for the links.
#12 | |
I can get the wheels and tires from these take offs. I'd just bring them to a tire shop and have them swapped. ![]()
#13 | |
#14 |
Jeep Jedi Master
As long as those longarms say Claytons on them that is just fine. If they say RK, you need to spend your money elsewhere.
Hunter
#15 |
How about Kevin's, Hunter? You prefer Clayton's over his?
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
