Anyone Ever Use K-seal??? - JeepForum.com
post #1 of 18 Old 10-06-2009, 11:32 PM Thread Starter
CULate
1930 J-Series Truck
I have a small leak in my heater core on my Limited 5.9. So today I decided on the shops advice that does a lot of my work to try K-Seal stop leak. They told me it will not plug up the heater core or radiator as many sealers do. So today I poured it in. I drove it about 10 miles & parked it. I will know more in the morning if it worked. It is made up of ceramic & copper. You just leave it in, & it mixed with all types of anti freeze.
Has anyone else ever used it?
CULate is offline
post #2 of 18 Old 10-07-2009, 12:04 AM
sandman
i havent used it, sounds sketchy though.
1993 Jeep ZJ. 4.0
sandman is offline
post #3 of 18 Old 10-07-2009, 12:09 AM
Mopargearhead
I don't trust any type of sealer no matter how much they claim it won't cause damage. I had a customer use it to try and seal a leaking water pump on his Dodge Sprinter and it ended up costing him a $600 radiator, new water pump (obviously), and flushing the system multiple times to get the gunk out of the heater core and engine block.
Mopargearhead is offline
post #4 of 18 Old 10-07-2009, 12:50 AM
dckaz
wow not to get off topic but why wouldn't someone just replace a water pump
dckaz is offline
post #5 of 18 Old 10-07-2009, 11:48 AM Thread Starter
CULate
1930 J-Series Truck
I agree, but I thought I would try it. Heck, a heater core is a BIG JOB. If I can put it off I'll give it a try. The shop that told me to use it has had great success with it. My heater core only leaks when cold once it heats up it stops. As explained to me that Jeep used a plastic with metal core, just like the radiators. & as they get old they seem to seep when cold & when they heat up they stop because of the expansion of metal. I don't have any liquid on the floor or anywhere. Just when you start it in the morning if I don't drive it regularly I smell anti-freeze until it warms up then it quits. Every so often I get a small amount of fog on my windshield.
I'll let you guys know if it does the job.
PS. I know that Alum-Seal & some others will cause all kinds of problems with these newer vehicles. Alum-Seal will as I'm told seal everything including the radiator tubes solid & heater core solid.
CULate is offline
post #6 of 18 Old 10-08-2009, 09:54 PM Thread Starter
CULate
1930 J-Series Truck
Well, This morning the wife drove the Jeep to work & she said the smell of anti-freeze was gone. So The K-SEAL must of worked. So it seems to be an option to replacing them if they are not too bad.
CULate is offline
post #7 of 18 Old 10-08-2009, 10:28 PM
indianajeep
indianajeep's Avatar
2005 WK
time will tell - usually those stop leak fixes are temporary at best. But good luck. I speak from experience of buying a ZJ that was full of that stuff - first time the antifreeze was changed - tada - antifreeze leak reappeared - new radiator, new engine, etc. The stop leak was temporarily hiding cracked block, cracked heads and a radiator full of holes.
indianajeep is offline
post #8 of 18 Old 10-09-2009, 10:07 AM
subliminal
1997 XJ Cherokee
On top of it only being a temp fix your heater core will now not work as effectively since that stuff is coating the inside of it and it will be hindering heat transfer.
1997 Jeep Cherokee 4.0 Automatic NP231
subliminal is offline
post #9 of 18 Old 10-09-2009, 10:12 AM
comishcraig
Wow...that's some pretty good stuff if it can stop that much from leaking.
2000 Saab 9 3 Viggen - Daily Driver
2004 Honda Odyssey - Baby Hauler
1981 VW Scirocco - Featured in Jan 2001 Sport Compact Car Magazine
1997 Jeep Grand Cherokee Limited 5.2 - Mountain fun Vehicle
1996 Kawasaki 750ss - Lake fun
1996 Kawasaki 750xi - More lake fun
comishcraig is offline
post #10 of 18 Old 10-09-2009, 10:26 AM
rugermack
It would be nice if that stuff really worked, it's a band aid on a cut that needs stitches. All that stuff you pour in your radiator has to accumilate somewhere, there are areas you don't want it to accumilate.
Unhook your heater core hoses until you can fix it the right way. Shop around for a good heater core, so you don't have to tear it apart twice.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts
rugermack is offline
post #11 of 18 Old 10-09-2009, 02:23 PM Thread Starter
CULate
1930 J-Series Truck
Well we will see if & how long it works. The worst case is I will have to take it to the shop that advised using this & does a lot of work for me & have a new heater core installed. It is only $600.
In the old days I use to fix radiator leaks with yellow mustard.
CULate is offline
post #12 of 18 Old 12-26-2010, 02:43 PM
Tony01
The micro particles that k seal use do not gather anywhere, or clog anything, they circulate around the system until there is a leak which causes a small loss in coolant pressure. They are then drawn to the leak blocking and fixing said leak. I have a 95 wrangler 4l limited with k seal in for last 5 years no leaks, no blockages , no problems. If using a sealing product I suggest a cooling system flush first to ensure no blockages before use.
Tony01 is offline
post #13 of 18 Old 11-09-2014, 09:27 PM
new2site
CUlate...is that stuff still holding up for your heater core??
If it still is 5 years later I'm going to buy stock in it.
new2site is offline
post #14 of 18 Old 11-10-2014, 11:59 AM
new2site
Anyone else use this for a heater core with long term success?
new2site is offline
post #15 of 18 Old 11-10-2014, 12:48 PM
Pierre_r
1989 XJ Cherokee
I have not used K-seal but i have used Bars leaks when my radiator started to leak a few years ago.
It held for about 6 months then i had to replace it.
No issues with it blocking things that other sealers do
Jeep Cherokee XJ 4.0 -89
Jeep Cherokee XJ 4.0 -90 (partsjeep)
Jeep Grand Cherokee 5.2 -93
Chevrolet Silverado 2500 6.5TD -94
Chevrolet C20 6.2 -82
Pierre_r is online now
WJ rear axle seal (no inner seal???) cmonson ZJ Grand Cherokee Forum 15 08-02-2009 10:50 AM
Trans Output Seal & TC input seal shop pricing graffix000 ZJ Grand Cherokee Forum 0 05-05-2009 01:35 PM
WJ rear axle seal (no inner seal???) cmonson ZJ Grand Cherokee Forum 0 04-28-2009 04:49 PM
1993 Oil Filter Adapter seal kit is not #04720363. What is the correct seal kit ??? Panchojeep ZJ Grand Cherokee Forum 2 04-11-2008 09:38 AM
What seal is this? draxxuspainter8 ZJ Grand Cherokee Forum 2 11-10-2007 12:38 PM
