Anyone add a spring loaded belt tensioner to the 4.0? - Page 2 - JeepForum.com
post #16 of 21 Old 11-12-2013, 06:44 PM Thread Starter
93zjer
Im glad we have this forum to work this stuff out. I know that even the "p/s tension setup" isnt really that slow or frustrating but many of us are tinkering with our jeeps or friends jeeps so often that these little time saving mods can be very worthwhile. Im trying to get through mid-terms right now but I'll let everybody know if I get any more info here. I believe 1994 ZJ is probably correct in the above post.
93zjer is offline
post #17 of 21 Old 11-12-2013, 06:48 PM
somebody5788
1994 ZJ
It is for mine... the bolt is really corroded so it's very hard to move it.
2006 Honda 919 - Summer Daily
1994 Jeep ZJ - RC Long Arms | RE 4.5" springs | Bilstein 5100's | RE SS brake lines | Falken 31x10.5-15 tires | Flatland 4x4 bumpers | Summit Soft 8's 15x8 3.75 BS wheels
somebody5788 is offline
post #18 of 21 Old 11-12-2013, 07:47 PM
rayacky
1999 ZJ
Hi, just spotted this thread, & can confirm my RHD 99 ZJ is adjusted by the alternator as well, & i would not bother changing.
By the way it is a lot easier to get to than the one in the pictures. Cheers Ray.
rayacky is offline
post #19 of 21 Old 11-12-2013, 09:55 PM
coralman
USER OF PARTS CATALOGS
coralman's Avatar
Good idea, but I got too much stuff that needs fixin' to hunt new things to do
Originally Posted by HighLonesome
coralman is offline
post #20 of 21 Old 11-13-2013, 03:33 AM
Marcos
Summary of 4.0 belt tensioning setups (LHD, don't know about RHD myself):
Up through 95: adjusted via the PS pump. Loosen 3 bolts + locknut, then adjust tensioner bolt.
96-98 zj + xj up to 01: tensioner pulley below PS pump. Loosen locknut, then adjust tensioner bolt (change required re-routing belt, removing 1 idler near alternator, adding tensioner pulley, new mounting bosses cast into intake manifold to accept direct mounting of PS pump)
99-up (wj + some tj): spring loaded tensioner near alternator. Belt was re-routed, alternator raised, a/c comp relocated below PS pump.
Marcos is offline
post #21 of 21 Old 01-16-2015, 01:17 PM Thread Starter
93zjer
I was doing some serious looking at the junk yard the other day. I believe we can convert to the newer setup with a spring loaded belt tensioner but I dont have the cash to get the appropriate parts at this time.
93zjer is offline
