Anybody used Bars Stop Leak?? - JeepForum.com
post #1 of 7 Old 09-15-2009, 06:01 AM Thread Starter
WXman
I need a new rear main seal. Mine leaks some. I also have the small head gasket leak that is common. But before I rip into all that work, I saw this stuff advertised called BARS Stop Leak that is specifically designed for rear main seals. Anybody use that stuff?
'92 YJ - heavily modded
'96 ZJ - heavily modded
'05 KJ CRD Limited - 370 lb./ft. from a 4-cylinder and trail ready. Pure awesomeness.
'11 Mango Tango JKU Sport - Mods
'12 Dozer JKU Sport S - 6-speed - ACE rock rails - Max Tow package - Daystar spacers - 33x12.50 Duratracs
WXman is offline
post #2 of 7 Old 09-15-2009, 06:41 AM
318jeepcherokee
a guy came into my work with very little money and his rad was leaking really badly from a whole right i the middle of it, he asked what he could do to get by, in reality he needed a rad but we decided to throw in a bottle of stop leak( not sure of the brand) in it just to se if that could help him for a bit and yep it sealed it right up. still isnt leaking. (month later)
i know this a rad not a main seal or head gasket but i would think it still might apply.
connor.
-1998 grand cherokee 5.9- custom intake, MTX sledge hammer sub with two JBL audio speakers in the rear doors and JVC deck, Westin safari bar with two 6' lights, Yakima load warrior with reverse lights, Hooker aero chamber muffler.
318jeepcherokee is offline
post #3 of 7 Old 09-15-2009, 07:26 AM
squashman702
1994 ZJ
It's a band aid until you can get a permanent fix.
Think Twice Garage
"I guess I'd just run it?"
squashman702 is offline
post #4 of 7 Old 09-15-2009, 09:05 AM
JensGCherokee
Bars Leak or any leak fix is bad for any vehicle.. For a temp fix (a few weeks) is fine, but after that it starts to clog up the flow ports & also does in the thermostat. After getting a new Rad, before you put it in, FLUSH THE SYSTEM really good!!! You want to get whatever is left in there out.
I pay my mechanics with Oreos & Gummie Bears!!
JensGCherokee is offline
post #5 of 7 Old 09-15-2009, 09:09 AM
rugermack
Could clog some of the tubes in the rad, or in the engine block.
95' Jeep Grand Cherokee Laredo, 148k, 5.2, NP242, 46RH, 4" RC lift, all new adjustable ca's(2 IRO front uppers and the rest RC adjustables), nitro shocks, JKS TB's, Jet Chip, Dynamax cat back, Magnaflow cat, GTP hood vents. 31" Pro Comps with Rock Krawler "D"s. Westin brush/grill guard with Hella 500s, 411's, Solid diff covers, detroit locker rear, power lock in front, SYE and Tom Wood's front/rear shafts, RE discos, BPE's, d-rings front and back, factory tc and rad skid, hitch, Sliders next.
03' Jeep Grand Cherokee Laredo, (wifes Jeep) 99k, 4.7 5 speed auto, K&N, KYB shocks, drilled-slotted rotors, All the toys.
2000' Ford Superduty, F250, 7.3, 198K, 37's, too much to list.
Built Not Bought #257
Parts for sale d30 and d35 parts
rugermack is offline
post #6 of 7 Old 09-15-2009, 09:32 AM
WiCkeDuDe
WiCkeDuDe's Avatar
Yeah Ive had it clog up heater cores on me. Yes I closed if off when I added it.
I Have WJ Stuff for Sale
WiCkeDuDe is offline
post #7 of 7 Old 09-15-2009, 09:35 AM
Rmart30
Ive seen cars come into the shop that have had bars leak and others in the radiators...... bad bad stuff, clogs up badly in thermostats and heater cores.
As far a something for "sealing" oil leaks. It has chemicals that cause seals (rubber) to swell. Most motor oils have a small amount of it added to them to keep seals from getting brittle.
Its a "band aid fix" at best.
Rmart30 is offline
Anybody ever used Bar's Leak or Alumaseal radiator stop leak? scarthearmada6 ZJ Grand Cherokee Forum 23 05-02-2014 03:10 PM
Transmission Stop Leak JeepMax ZJ Grand Cherokee Forum 13 10-04-2009 01:28 AM
AC leak stop tirus89 ZJ Grand Cherokee Forum 3 05-22-2009 07:26 AM
Transmission stop leak? djdoug99 ZJ Grand Cherokee Forum 9 10-23-2007 10:04 PM
Is Stop leak a good ac fix Mustang ZJ Grand Cherokee Forum 4 07-11-2005 12:55 PM
