Anybody run into this problem? - JeepForum.com
post #1 of 9 Old 03-06-2013, 05:28 PM Thread Starter
DeejayZeejay
1994 ZJ
98 Jeep zj with a 4.0. This Jeep has been to hell and back. Lots of miles and issues.... Trying to keep it going for a little longer. I replaced bcm because of faulty original with internal short. Fixed the drain. Rebuilt alternator, starter and new battery. Cleaned every connection as well. Now only starts with a jump start. Starts right up and will drive fine. Park it and try to start it again and nothing. No power anywhere. Battery is fine. My next fix will be the battery cables and clamps. Any thoughts?
Jeeps 4 Life!
DeejayZeejay is offline
post #2 of 9 Old 03-06-2013, 06:16 PM
MtnboyBamm
Location: In between Bakersfield and Valencia Ca in a small town called Frazier Park
I was having a similar problem too. Cleaned the battery terminals and bought new clamps for it. Not a single problem since. GC's are touchy when it comes to battery issues...
MtnboyBamm is offline
post #3 of 9 Old 03-06-2013, 07:00 PM
jnicewan
Where are you hooking the cables for the jump? This might tell you where the problem could be. A good battery, good terminals (clean and tight ) and good cables should not need a jump.
jnicewan is offline
post #4 of 9 Old 03-06-2013, 08:19 PM Thread Starter
DeejayZeejay
1994 ZJ
I hook the cables straight to the post on both. I think the battery cables are original and I can see green corrosion where it goes into the wire shield. Its just weird that nothing comes on when I turn the key. No lights, gauges, nothing....
Jeeps 4 Life!
post #5 of 9 Old 03-07-2013, 03:37 AM
KoreaZJ
1994 ZJ
Last cable connected (NEG) always goes to bare metal on the disabled vehicle, NOT the battery. Engine or frame connection away from battery.
Creating sparks near the battery can ignite/explode a battery.
I've seen it close up. Don't risk it.
KoreaZJ is offline
post #6 of 9 Old 03-07-2013, 06:35 AM
PeteNnewburg
I had the same problem when I got my ZJ. It had a new alt and battery. After noticing the hammer marks on the starter, I replaced it. Still would not start without jumping. Voltage guage was all over the place. While cleaning the battery terminals again, I noticed the body ground was rusty and neg cable corroded (green). I replaced both cables cleaned the grounds and added a extra ground from firewall to the engine/ starter bolt.
Every thing now works great! Starts instantly, no more misses at idle. My non-working windows and door locks now work and gauge holds steady at 14 volts.
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
PeteNnewburg is offline
post #7 of 9 Old 03-07-2013, 06:48 AM Thread Starter
DeejayZeejay
1994 ZJ
So you replaced both battery cables and added a ground to the starter?
Jeeps 4 Life!
post #8 of 9 Old 03-07-2013, 07:04 AM
PeteNnewburg
Yes. The cables on a ZJ split off in a few different directions! If possible buy OE cables! These things are really finicky about the electronics. I had to splice and solder the Negative cable. It comes off the battery terminal in two wires, one to the body, the other goes down to the block, but also splits off to the alternator with a special connector.
There is one on Ebay, looks like crap, but you can see how the cables run. # 261178514480
I added the extra body ground out of habit, I've owned a lot of Fords!
2000 Cherokee
1983 Ranger 5.0
1998 Mustang
post #9 of 9 Old 03-07-2013, 02:54 PM
cootertwo
1997 XJ Cherokee
Yup, these things need GOOD grounds. I too cleaned all the stock connections, and added a couple more ground cables. I had a basket full of made up cables from old golf carts.
cootertwo is offline
