any way to keep water off belts and pulleys or do i have a different issue? - JeepForum.com
post #1 of 10 Old 08-14-2013, 06:42 AM Thread Starter
SewerRat114
I work for a water treatment facility and part of my job is going out to the wells and lift stations and I use my jeep for it. With the 10+" rain just this month the roads are unkept and rutted so when I splash through I kick water up on the belt and pulleys and loose charging and power steering....is there a skid i can add or do I have a different issue to look into?
SewerRat114 is offline
post #2 of 10 Old 08-14-2013, 07:01 AM
Pierre_r
1989 XJ Cherokee
Do you still have that rubber piece of **** splashguard under the engine that was on the jeep from the factory?
If not put one on.
Pierre_r is offline
post #3 of 10 Old 08-14-2013, 07:23 AM
zj97ltd
I hope you get vehicle allowance for that.
zj97ltd is offline
post #4 of 10 Old 08-14-2013, 07:42 AM
WhiteOut
WhiteOut's Avatar
Getting the belt wet won't cause a loss of charging and power steering.
WhiteOut is offline
post #5 of 10 Old 08-14-2013, 08:31 AM Thread Starter
SewerRat114
There is something off the radiator hanging down a bit but nothing from the radiator back protecting/covering that area under the crank pulley. I do get compensated for useing my own vehicle.
What I am figuring is that I am splashing water up on the belt and its slipping, preventing the power steering pump and alternator from spinning correctly...if I am wrong in my thought process please educate me.
These aren't street puddles...I am inches from my rockers in some of these ruts headed out to the wells.
post #6 of 10 Old 08-14-2013, 08:54 AM
PolkaPower
I have driven through plenty of deep water crossing and gumbo mud sometimes past the rockers. Never had that problem. Is your belt tensioner worn out or not tight enough?
Try slowing down as well.
PolkaPower is online now
post #7 of 10 Old 08-14-2013, 12:24 PM
KJK
You are absolutely correct. The belt hydroplanes on the pulleys.
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline
post #8 of 10 Old 08-19-2013, 05:50 AM
Higgins
Doesn't sound right....................
The radiator shroud on the jeep is a lot deeper than a lot of cars these days, and there is a flexible rubber that is secured from the radiator shroud to the side rails and covers the front part of the engine to keep water / mud from splashing up on the engine!
With that said, we've had both our 95, 96, and 98 jeeps in water deep enough that the fan bladed were hitting the water, with no effect on the jeep operation.
Maybe you should consider checking the tension on your belt, or replace the belt ans see what happens!
Higgins is offline
post #9 of 10 Old 08-19-2013, 10:19 PM
coltman151
Mine did that. Found it out trying to cross a flooded stream.
Tighten the belt. Even if it seems tight, tighten some more. If that doesn't help, replace.
95 Laredo 4.0, 2" RE BB, RC N2.0 Shocks, Custom Roof-Mount Light Bar w/ 6 lights, Bumpers deleted, Homemade sway bar discos, Michelin LTX 31x10.50s, and a Dog Box :)
Planned: Homemade Spare tire carrier, double shear front track bar, 4 adjustable rear control arms, New Rims and 33" Wrangler MT/Rs or BFG M/T KO's w/ LOTS of trimming.
coltman151 is offline
post #10 of 10 Old 08-20-2013, 01:31 AM
Oldfrog
2007 WK
I agree with tightening the belt. Put a gates belt on it. If it has a Dayco or some autozone belt....keep it as spare and install a Gates....tightly. We run in rain all the time and you know water splashes up there, yet no one is complaining of slipping belts.
Is your battery running down? If so, it's another issue...not a wet belt.
2007 5.7 Hemi, Ltd. QD II -
1997 ZJ, 4,0 select trac, Up country, track lok.
Oldfrog is offline
