any trick to removing plug wires? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > any trick to removing plug wires?
New DEAL OF THE WEEK at ROCKRIDGE 4WD!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 08-25-2014, 10:15 PM   #1
pedalboy2001
Went to go replace the spark plugs in my 5.2l but the plug wires don't seem to want to pull off. I wasn't looking to replace the wires and don't want to damage them but if I grab on with pliars I take risk of damaging the wires. Is there a trick to this? I see what appears to be guards but wanted to make sure there isn't a locking tab that I wasn't aware of. I'm not sure this has ever been done on this vehicle.
pedalboy2001 is offline   Reply With Quote
Unread 08-25-2014, 10:22 PM   #2
JS97ZJ
Twist the boot then replace them with dielectric grease.
JS97ZJ is offline   Reply With Quote
Unread 08-26-2014, 06:43 AM   #3
94cherry
1994 ZJ
There is a special pair of plug wire pullers you can buy. Never pull by the wire, always pull the boot and twist back and forth to get them loose. Watch those shields they are sharp as a razor, I cut my thumb on one pretty bad.
Authority should derive from the consent of the governed, not from threat of force!
94cherry is offline   Reply With Quote
Unread 08-26-2014, 07:33 AM   #4
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
Get rid of the stupid shields and use high quality wires. And the removal pliers are the way to go sir^
HighLonesome is offline   Reply With Quote
Unread 08-26-2014, 07:49 AM   #5
KJK
Those shields can hold a lot of dirt in there as well. Make sure to check before pulling the plug out because all the dirt will fall into the plug hole! Doh!
5.9 ZJ SCT tuned PCM/ KJK CAI/ Thorley headers with 3" Magnaflow cat and muffler/ Modded kegger/ TransGo shift kit/ Vanco brake kit/ Braided steel brake lines/ Mopar cupholder insert!
KJK is offline   Reply With Quote
Unread 08-26-2014, 08:11 AM   #6
HighLonesome
good call on the dirt!
I brush the hole rigorously with an acid brush, then shop air. Repeat as necessary.
Unread 08-26-2014, 08:32 AM   #7
NTH
Are the shields easily removed?
NTH is offline   Reply With Quote
Unread 08-26-2014, 09:14 AM   #8
firsttimeZJ13
Grab with pliers, twist and pull. They squeeze together to go back in if you choose. You will see what I mean.
1995 ZJ, 5.2L, NP249, stock suspension, e-fan, CAI, engine needs work!! Plan on lift and tires when money finds its way here...
firsttimeZJ13 is offline   Reply With Quote
