Any recommendations on a good rear axle shaft for a D44a? - JeepForum.com
post #1 of 12 Old 07-08-2011, 02:50 PM Thread Starter
DukeMalisto
I just got some news from the shop, saying the bearings are shot (I knew this) in the rear diff (a dana 44a) and he saw the right rear axle was worn where it meets the bearing on that side.
I looked up the parts, and his part quote matches both results found on RockAuto. Does anyone know where I might get a good used or new rear right axle for cheaper or at least confirm which part number will fit my Jeep?
From Rock Auto:
DORMAN Part # 630302 More Information About this Part {#4856333} Length: 30-1/4"; Number of Holes: 5; Spline: 30
Includes Bearing, Seal, Studs and Lug Nuts; Rear Left; w/Dana 44 Axle $246.79
DORMAN Part # 630305 More Information About this Part {#4856332} Length: 29-1/4"; Number of Holes: 5; Spline: 30
Includes Bearing, Seal, Studs and Lug Nuts; Rear Right; w/Dana 44 Axle $250.79
What I'm running into right now, is lots of dealers are selling for Dana 44, but don't specify Dana 44a.
A side question: What side gears would I need to get for my Diff? Apparently those are worn pretty badly causing a lot of wharbling noise in the rear end when I'm coasting, not so noisy when under torque. Problem is, I don't know much about a diff, don't have a way to work on one myself (apartment) and I've never heard it put as "Side gears" in all of my reading for diffs....
Thank you for your help in advance. I'm trying to save what I can, but fix what I must, before my honeymoon road trip next month
DukeMalisto is offline
post #2 of 12 Old 07-08-2011, 10:50 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Side gears= spider gears. It's what makes a differential differentiate.
Thats the going rate for new shafts. They never have been cheap.
I've still got an old spare set, but doubt you want to wait on cross country shipping.
ratmonkey is offline
post #3 of 12 Old 07-08-2011, 11:14 PM Thread Starter
DukeMalisto
What'll it cost? I don't have to get the axle shaft right this second and it'll only take me an hour to slide into place. Zip is 98136
Also, any idea what the length measurement is all about (why there are two lengths for the same jeep and axle)?
post #4 of 12 Old 07-08-2011, 11:20 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
Left and right side are different length.
Pm me if you want the shafts. we'll talk that way.
post #5 of 12 Old 07-09-2011, 05:15 AM
Technohead
You might as well get Yukon alloys instead.
-Eric
Technohead is offline
post #6 of 12 Old 07-09-2011, 06:20 AM
AlphaLorde
Not to totally highjack but.....
Are these the yukon alloy shafts part #s?
right:YA D74871-1X
http://www.yukongear.com/ProductDeta...px?ProdID=3380
left:YA D74871-2X
http://www.yukongear.com/ProductDeta...px?ProdID=3378
I would like to know cuz if my shafts are shot when I get my 44a torn apart next weekend, I would rather spend a little more to get a way better product.
1998 ZJ Laredo 5.2L 139k 231 w/SYE artec trussed 8.8 4.25"F/5"R lift
AlphaLorde is offline
post #7 of 12 Old 07-09-2011, 11:41 AM
CatSplat
1994 ZJ
Those look to be correct for a C-clip D44A, but I would call and ask just to make sure. As a bonus, the price on Randy's Ring and Pinion for that axle is $198 - cheaper than the OEM one from RockAuto. A no-brainer if you ask me.
Superior also makes their ZJ D44A shafts for $150 each, I'm not sure how they compare to the Yukons in strength. The Superior site lists their PA5225 as a replacement for the Yukon axles you listed above, indicating the Yukons are likely the right shaft for the ZJ.
http://www.superioraxlegear.com/pa52...d-p-14260.html
1994 5.9L ZJ, retrofitted UC package, NP242 swap, 17" JK Moabs with 32" BFG MT KM's.
The Jeep of Theseus
CatSplat is offline
post #8 of 12 Old 07-09-2011, 12:58 PM
gothchick
I was totally going to say that. I got Yukons and have been very happy with them. I have a d35 though...
Don't fear the regear.
Finished 4x2 --> 4x4 conversion.
gothchick is offline
post #9 of 12 Old 07-09-2011, 03:42 PM
5.9 ANDY
zj tractor
5.9 ANDY's Avatar
if you are going to have to regear your axle too... i highly recomend throwing in some 4;10 gears.
hard working private first class in the United States Marine Corps.
Originally Posted by shift_grind View Post
It's threads like this that make me wonder why people lift there jeeps
its comments like this that make me wonder why some people are jerks.
build thread:
5.9 ANDY is offline
post #10 of 12 Old 07-09-2011, 03:45 PM
jforse
I would definitely go with the Superior shafts over the Yukons.
1997 TJ - Build in process.
2004 WJ Freedom Edition 4.7HO
jforse is offline
post #11 of 12 Old 07-11-2011, 03:53 PM Thread Starter
DukeMalisto
Thanks guys, I'll check out Randy's Ring and Pinion on a new shaft for now. Don't need regearing or anything.
The spider gears however, I do not know for sure what part number to get as what I'm finding only lists for Dana 44, not specifying 44a or HD. I'm looking to get something cheaper than the shop quoted (250 for parts). I guess I'll check with Randy's on that, too.
post #12 of 12 Old 07-11-2011, 03:56 PM Thread Starter
DukeMalisto
Wow, found the spider gears on superior axle's site, too. Favoriting that store, hah!
Thanks everyone for helping me out on this. I'll upgrade both rear axles to something stronger when I've some play money (that is, if the new wife lets me have any, haha)
Rear axle in 5.9? D44a? yjJEEPyj ZJ Grand Cherokee Forum 16 06-26-2011 11:57 AM
Axle loud axle whine from D44a jopolly3 ZJ Grand Cherokee Forum 21 04-24-2009 11:51 AM
Anyone got a way to pull a rear axle on a D44A? allenjp ZJ Grand Cherokee Forum 23 01-17-2009 08:52 PM
WJ D44a axle into a 97 ZJ drespecki ZJ Grand Cherokee Forum 11 05-23-2008 09:19 PM
Pulling rear WJ axle shafts....D44a AgitatedPancake ZJ Grand Cherokee Forum 24 01-28-2006 03:41 PM
