any pictures of changing pinion seal of grand cherokee 1999 - JeepForum.com
post #1 of 26 Old 02-28-2008, 12:30 AM Thread Starter
shahriarrrr
Hi,
I'm going to change my pinion seal but need guidance in form of pictures/ videos.
I appreciate any help
shahriarrrr is offline
post #2 of 26 Old 02-29-2008, 12:34 AM Thread Starter
shahriarrrr
Any help? any comments?
post #3 of 26 Old 02-29-2008, 12:38 AM
BucYouUp68
Ummmmm, are you a Mechanic, do you have all the tools for this. It is quite involved
Why is there a fish finder in your Jeep?
Not hard, if you have a socket wrench and the mental capacity of a ham sandwich.
BucYouUp68 is offline
post #4 of 26 Old 02-29-2008, 05:54 AM
crosschecker
1995 XJ Cherokee
Originally Posted by shahriarrrr View Post
Hi,
Get yourself a manual for starters. It's not an extremely difficult job, but you really need to know what you're doing and what tools you'll need before you consider it.
'95 XJ 4.0, 2wd converted to 4wd, manual and stock
'96 XJ 4.0 Country, Auto (The new kid)(now in need of an engine)
'99 WJ 4.0, stock
'96 ZJ 5.2 Limited
crosschecker is offline
post #5 of 26 Old 02-29-2008, 12:05 PM Thread Starter
shahriarrrr
I've find this but I'm not sure that the Grand cherokee's be as straight forward as this:
http://tija.org/writeups/PinionReplacement.html
any comments over that?
and even this one has better pictuers:
http://www.jeepingsingles.net/tech/pinionseal.asp
I appreciate any comments that help
post #6 of 26 Old 02-29-2008, 01:21 PM
Turbonut
Didn't read the second, but I believe the first didn't mention to apply lube to the seal lip before installation. Just be careful when tightening the nut back down. Do not overtorque or you'll be doing a bearing replacement in the future.
Turbonut is offline
post #7 of 26 Old 02-29-2008, 01:41 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
I have been trying to figure out the same thing. I got a new front DS waiting to put on and IDK how to replace the seals yet. The Haynes manual doesnt mention a thing about it...
NEW Dana 44a Axle Truss and Skid !
WJ Grand Cherokee Tube Doors For Sale !
ZJ Grand Cherokee Tube Doors For Sale !
PARTS FOR SALE from 10 WJ Grand Cherokees ! !
QuadraTokn is offline
post #8 of 26 Old 02-29-2008, 01:45 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
QT I still have your PM, just haven't had a chance to read/answer it yet
'14 WK2 Limited w/5.7L, ORAI, & Tow Package
ArloGuthroJeep is offline
post #9 of 26 Old 02-29-2008, 01:50 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
Found it in the FSM. Seems to be more involved than i thought.
post #10 of 26 Old 02-29-2008, 01:52 PM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
oh ok thats good. take your time.
BTW, what is the seal called on the t-case side?
post #11 of 26 Old 02-29-2008, 02:15 PM
ArloGuthroJeep
Mr. Hyde!
TC front output seal
post #12 of 26 Old 02-29-2008, 11:01 PM
LTD 318ZJ
I think this guide here is easier to understand compared to that b&w guide that was posted.
You will need a slide hammer with a seal puller or a leverage style seal puller.
Like said before when you tighten the pinion nut down be careful!! Over tightening this will burn out the differential. I believe the torque for the nut is specd at 175-250ft-lbs. so if your torque wrench doesn't read that high, then note the number of thread the pinion nut sits down on. Then lock-tite the nut back down to where the threads previously rested.
LTD 318ZJ is offline
post #13 of 26 Old 03-01-2008, 12:14 AM Thread Starter
shahriarrrr
I plan to do that tomorrow, and actually my torque meter will not read more than 150, so I plan to borrow or count the number of threads, as you said.
post #14 of 26 Old 03-01-2008, 12:16 AM Thread Starter
shahriarrrr
do you know where can I find the 1999's FSM?
post #15 of 26 Old 03-01-2008, 12:20 AM
QuadraTokn
QuadraTokn's Avatar
1930 WJ
check ebay or your dealer. maybe somewhere else if anyone knows
1998 grand Cherokee 5.9 vs 1999 Cherokee 4.7 rrich49132 ZJ Grand Cherokee Forum 89 11-27-2010 06:11 PM
1999 grand cherokee. which rear end? zarkon0007 ZJ Grand Cherokee Forum 6 07-28-2009 08:47 AM
Changing Rear Pinion Seal flinthills76 ZJ Grand Cherokee Forum 16 03-31-2009 08:54 AM
Changing rear pinion seal without inch/pound torque wrench, any experience? shahriarrrr ZJ Grand Cherokee Forum 3 03-15-2008 03:57 PM
1999 Grand Cherokee m.p.g. issues daveyboy43 ZJ Grand Cherokee Forum 1 01-22-2007 09:11 AM
