Any good write-ups for replacing the 5.2L intake manifold gasket? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Any good write-ups for replacing the 5.2L intake manifold gasket?
Brand New! Quadratec LED Headlights!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 08-25-2014, 08:51 AM   #1
Haus_XJ
I have a vacuum leak and believe it is the intake manifold gasket.
I purchased the repair kit and now am looking for a good write-up on how to replace the gasket and associated hardware.
Has anyone seen a decent write-up on this?
Haus_XJ is offline   Reply With Quote
Unread 08-25-2014, 08:55 AM   #2
firsttimeZJ13
Search for plenum gasket repair. Since you have to take the intake off, do that!! If not, you will sooner or later anyways. Clean the throttle body really good as well as sensors. Label wires or take pics before removal so you remember what goes where.
1995 ZJ, 5.2L, NP249, stock suspension, e-fan, CAI, engine needs work!! Plan on lift and tires when money finds its way here...
firsttimeZJ13 is offline   Reply With Quote
Unread 08-25-2014, 09:01 AM   #3
Haus_XJ
Thanks! Yeah I definitely want to knock out anything else I can while I'm in there.
Unread 08-25-2014, 09:11 AM   #4
Haus_XJ
Here is the kit I bought:
http://www.1aauto.com/intake-manifol...FUVo7AodqSkAkg
Not sure what the plenum gasket looks like, so maybe you can tell me whether or not this kit includes one?
Unread 08-25-2014, 09:17 AM   #5
Haus_XJ
I think I found a little info, but no write-up:
http://www.jeepforum.com/forum/f13/z...itions-591821/
Unread 08-25-2014, 09:42 AM   #6
HighLonesome
Belief In All Things Jeep
HighLonesome's Avatar
yes, looks to have everything you will need
HighLonesome is offline   Reply With Quote
Unread 08-25-2014, 11:16 AM   #7
firsttimeZJ13
It's the gasket to the right of the gaskets that go between the heads and intake. When you take the intake off, flip it over and you will be staring at a removable plate. That's where it goes and it's notorious for blowing out which causing backfiring, loss of oil and power. Once you take that plate off, if its got oil and crud built on it, it was bad! Clean everything VERY well and put back together! Short version, remove air hat, all electrical connectors, remove accessory bracket, disconnect fuel line and water hoses, take off intake, clean and reinstall everything. You'll need new antifreeze since you will have to drain system and there is a small bypass hose from the intake to the water pump. Go ahead and replace it as well. I'm sure there's more, I've had to take it off three times now... I get faster each time usually! Haha
