Quantcast Any benefit with larger rims vs smaller, same tire size? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Any benefit with larger rims vs smaller, same tire size?
Old 10-24-2008, 11:52 AM   #1
aaron7
I see many people (and some on here) with 17, 18... even 20" rims with offroad tires!
Is there any benefit to having larger rims with the same size tires? Say 15" with 31's or 18" with 31s?
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, Edelbrock struts, lots of audio (see details)
89 MR2 MK1.5 - Body done, built 450whp 3sgte, 6 year project so far
89 MR2 SC - 317k! rims, cams, lsd, pulley, exhaust, intake, header, brakes, stereo, bushings... still going :)
74 CB360 - Lots of cool cafe stuff :D
aaron7 is offline   Reply With Quote
Old 10-24-2008, 11:56 AM   #2
ratmonkey
Living dead mod
ratmonkey's Avatar
more sidewall=more flex in the tire. the shorter the sidewall the stiffer the ride of the tire and the less it can deform when aired down.
ratmonkey is offline   Reply With Quote
Old 10-24-2008, 12:04 PM   #3
aaron7
But wouldn't you want flex so it doesn't pop off the bead? Maybe I just don't get the concept.
Old 10-24-2008, 12:27 PM   #4
AgitatedPancake
Frobot Fabrication
AgitatedPancake's Avatar
the flex is good because it lets the tread form to the terrain, so smaller rims are better. You will have a better ride with a 31 on a 15" rim than you would with a 31 on a 20" rim on the street also, rides softer
Frobot Fabrication Facebook
01 WJ 5 Speed Claytons LA's, 36" Iroks, 35 spline 9" rear, Custom Ruffstuff 60-9" front axle.
Build Thread: http://www.mallcrawlin.com/forum//showthread.php?t=7387
AgitatedPancake is offline   Reply With Quote
Old 10-24-2008, 12:32 PM   #5
WJ04
Wicked Pissah
WJ04's Avatar
In my opinion smaller rims are better for offroading, And larger rims are better for street queens that want the offroad look. not to say that there aren't people wheeling with 18's or even 20's ...but smaller rims allow for more sidewall hight and thats better for offroad.
2004 WJ Laredo-selectrac 242-I6- Amsoil drop in filter-Saguaro 4x4 Front 3/4" shackles, Rear hitch & Warn 3/4" shackle-Mopar Front skid,Gastank skid -IRO TC skid- RRO super sliders- 6.5'' IRO critical path lift -IRO extended rear arms-Bilstein 5125 shocks -IRO F&R 6.5'' Bump stops-Carolina drive shaft-16x7 black soft 8's - 34'' Super swampers-Yukon 4.11 gears -Ultimate RCV shafts - LockRight Locked ECGS bolt in rear D60 -35 spline Chomloy shafts -BTF HD diff cover -IRO Adj A-arm-OX Locked super D30 -OX HD diff cover -OX drive away lock-Rock Krawler d30 truss-Stillen rotors & Matrix pads-JKS Adj Track Bar-JKS Quicker discos -OME SD-40 Steering Stabilizer-Relocated washer bottle-Removed rear sway bar-Cobra CB-TomTom one XL navi-alpine deck
Built 44hd for sale
Still to come: Flowmaster 50suv
Western Mass 4X4 Club
October 2011 GCOTM Winner
Originally Posted by billyjp2 View Post
I burnout on puppies and kittens
Originally Posted by vwmaniacx View Post
Lets not and say we didn't.
WJ04 is offline   Reply With Quote
Old 10-24-2008, 12:36 PM   #6
MSoutham94
17's are the perfect balance. Road esthetics and offroad performance
MSoutham94 is offline   Reply With Quote
Old 10-24-2008, 12:39 PM   #7
93gc40
This is the case where smaller is better. Smaller wheels with larger tires wire work better offroad and ride smoother. Larger wheels may look more cool and with the lower profile may handle better onroad, but rougher ride. Do you want functional wheel/tire, or are you more interested on looks?
96 XJ 4.0 / 231 / 3.5" JY Lift/ 31" BFG /.....
93 VT1100 - Harley killer.
97 ZJ 4.0 / 242 / Stock
93 ZJ 4.0 / 2"BB / Wranglers / RIP-Gone but not forgotten.
If it aint dirty, it aint a JEEP, it's just a SUV.
93gc40 is offline   Reply With Quote
Old 10-24-2008, 02:01 PM   #8
CanadianZed-J
Originally Posted by WJ04 View Post
In my opinion smaller rims are better for offroading...
That's not just your opinion, that's a fact. 15" rims are good up until about 37" tires, max. After that there's simply not enough bead to hold that much rubber. That's why you see 38s+ on 18"+ rims.
Running 20" rims on 31" tires would be really horrible off-road. What will you do? Air down to 28 lbs? 31s on 15s you can safely run 12-14 pounds in the rocks. I run 9-12 in my 33x12.5x15s.
On the other side of the spectrum, low-pro tires aren't just for looks. Having less sidewall gives better handling. Basically the ride will be less jiggly as the tread doesn't have far to move with the short sidewall holding it. An exaggerated demonstration would be to run low air pressure on the street with your current tires. You'll see exactly what I mean about jiggly.
CZJ.
So I installed the flux capacitor but the Jeep just won't do 88 mph.
-'99 WJ Limited, 4.7, Patriot Blue, 2" BB, 31" Mall-Terrains, Pavement Princess
-'97 TJ, Stone White, 4" Superlift, 33" SSRs, lunchboxed rear, 12K Titan winch, and 2.5 litres of exhillirating performance.
CanadianZed-J is offline   Reply With Quote
Old 10-24-2008, 02:09 PM   #9
jerryjeeper
Old Jeep Guy
I like the 20" American Racing 6 lug wheels with 39.5 x 1350 IROC's. Good on street, better off road. I would pass on the simulated beadlock trim the next time. Larger tires still give the necessary side wall flex with the 20"ers.
jerryjeeper is offline   Reply With Quote
Old 10-24-2008, 02:10 PM   #10
AgitatedPancake
Frobot Fabrication
I've never heard of that, and apparently neither has Interco, maybe you should tell them. They have up to a 42" irok on a 15" rim, a 47" LTB on a 15" rim, and a 44" TSL on a 15" rim.
http://intercotire.com/tires.php?id=6&g=1
The only reason I see larger rims is when people go with larger axles (D60, etc) the brakes won't fit in a 15" rim.
Old 10-24-2008, 02:19 PM   #11
Texas ZJ1
Jeep Jedi Master
Texas ZJ1's Avatar
1994 ZJ
Sir,
for the next couple of years, 15s are great.
Hunter
94 5.9 Laredo 6.5 RE lift with 35 Maxxis Bighorns
and 33 Bridgestone Duelers
Detroit and true trac
Red Jeep Club Member
REDNECK JCM
Texas Jeep Owner #6
USN Jeep Club #4
http://www.kevinsoffroad.com/
602.841.3355
For your performance needs:
kolak@kolakperformance.com
480.998.3661
Texas ZJ1 is offline   Reply With Quote
Old 10-24-2008, 02:20 PM   #12
tsconver
Hooligan
tsconver's Avatar
2003 WJ
if you ask a tire manufacturer or a hardcore offroader they will tell you the general rule of thumb is that the rim should be half the diameter of the tire. 30" tire 15" rim, 32" tire can go to a 16" rim, etc.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
My Build Thread
A few goodies
http://s257.photobucket.com/albums/hh219/benumb55839/jeep/
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
http://www.zrxoa.org/
2006 Red Liberty
Wife's ride, pretty stock
http://i257.photobucket.com/albums/hh219/benumb55839/jeep/image0008-1.jpg
http://www.cnc4x4.org/
http://www.treadlightly.org/
tsconver is offline   Reply With Quote
Old 10-24-2008, 02:25 PM   #13
CanadianZed-J
I'll send them an email.
I should have included "recommended". From what I've collected there is some kind of ratio to consider when choosing rims for large tires. I've also seen 42s on 2wd trucks so in that case who cares about the rim size if the tires will forever be inflated at street pressure.
CZJ.
Old 10-24-2008, 04:25 PM   #14
Haleyrz
1997 XJ Cherokee
i agree with the smaller the better. I would also like to throw in the fact that low profile tires cost more. It would be cheaper to go with 31's with 15's vs. 31's with 18's. Its crazy that less rubber costs more, but its the sad truth.
Haleyrz is offline   Reply With Quote
Old 10-24-2008, 04:26 PM   #15
Haleyrz
1997 XJ Cherokee
oh and not to mention bigger rims cost more as well. If you want to show off, go with the bigger. If you want practical application and a modest, but still rather awesome look, stick with the smaller ones.
Glock Forum
