anti lock brake light problem - JeepForum.com
post #1 of 4 Old 01-20-2008, 03:59 PM Thread Starter
redjeepcherokee
My son's 99 V-8 grand cherokee has developed a problem with the anti lock light occasionally coming on and staying on until the engine is turned off. The light may come back on or stay of when the jeep is restarted. Other times the light will come on and then go off quickly for no reason. Otherwise, the brakes appear to be fine.
How serious is this light problem and what could be the cause?
redjeepcherokee is offline
post #2 of 4 Old 01-20-2008, 04:51 PM
Turbonut
The light being on and detecting a problem, will not affect the normal braking operation of the Jeep. Could be a dirty wheel sensor that is not sending a signal, to a faulty unit.
Dealer scan tool would pinpoint the problem area, but you might want to spray clean all the wheel sensors if you feel energetic.
Turbonut is offline
post #3 of 4 Old 01-20-2008, 07:14 PM Thread Starter
redjeepcherokee
what should he use to clean the sensors, just a brake cleaning spray?
post #4 of 4 Old 01-20-2008, 07:20 PM
WJChris
WJChris's Avatar
If there are alot of sand/dirt on the sensors, that will throw off the magnetic/inductive response, and think there is a problem.
Remove the wheel and just clean the area with water.....
I say no on using any solvents.
WJChris is offline
Anti Lock Brake Code 30....which part is this exactly?? jlcca844 ZJ Grand Cherokee Forum 8 12-01-2009 09:56 AM
Replacing CAB/HCU Anti-lock brake Unit. Any Suggestions on how? StillinSaigon ZJ Grand Cherokee Forum 0 09-30-2009 05:14 PM
Brake light problem, need help! shahriarrrr ZJ Grand Cherokee Forum 5 03-05-2008 08:08 PM
brake light problem Saint18z ZJ Grand Cherokee Forum 1 04-24-2006 09:40 AM
Brake Light Problem skitchi ZJ Grand Cherokee Forum 1 10-06-2004 05:50 PM
