anti lock Accel switch p/n 56006315 - JeepForum.com
post #1 of 7 Old 01-13-2007, 08:49 PM Thread Starter
tonysailor
I have a part, Jeep with a p/n 56006315. Off 97 ZJ. I know it is an anti-lock acceleration switch.
How does it affect ABS?
If it starts to fail what some indications?
And, what is it function? Any info is appreciated.
Tony
tonysailor is offline
post #2 of 7 Old 09-28-2012, 12:40 PM
niero
I know this is an old thread, but what is the acceleration switch? Is that the same as a wheel sensor?
niero is offline
post #3 of 7 Old 09-28-2012, 04:32 PM
Jerbear0612
First off good job reviving a 5 year old thread :P, but to answer your question (credit to Comanche freak via jeepsunlimited) it turns the abs light on and deactivates the and system
If the computer senses a failing component.
Jerbear0612 is offline
post #4 of 7 Old 09-29-2012, 01:09 PM
niero
Thank you, Jerbear
I'll ask my mechanic to check those. You wouldn't happen to have any other ideas on what could turn the ABS light on?
niero is offline
post #5 of 7 Old 09-29-2012, 01:39 PM
Scopez
1994 ZJ
Mine comes on and off. Its bipolar with that as well. I'll be pulling the wheels off and cleaning the connectors someday.
94 ZJ Laredo. 5.2 Crate engine. 6in JKS SA Lift. 33in Destination MTs. ARB Front Bumper.
Scopez is offline
post #6 of 7 Old 09-29-2012, 03:55 PM
niero
Yeah, I'll have to ask my mechanic if her actually cleaned all of those components off.
niero is offline
post #7 of 7 Old 09-29-2012, 10:31 PM
AVR2
There are numerous problems that could turn the light on, from a slightly misadjusted wheel sensor to complete failure of the ABS computer. There's little point in just guessing, if you can't see an obvious potential cause like a broken wheel sensor wire, you have to pull the trouble codes, which requires a professional-level scanner (the cheap ones aimed at DIY mechanics can't pull codes from the ABS, and there's no equivalent of the key dance trick for ABS codes).
I've just received the 1993 ZJ ABS diagnostic manual in the mail - $10 from eBay. It's got full diagnostic/repair flowcharts for every possible ABS malfunction, and there are a lot of tests that you need to do to isolate certain issues.
AVR2 is offline
ABS on No Anti-Lock Action acemechanic ZJ Grand Cherokee Forum 8 09-10-2010 01:04 PM
Anti-Lock Brakes steve L. ZJ Grand Cherokee Forum 14 03-08-2009 11:06 AM
Anti-Lock Brakes steve L. ZJ Grand Cherokee Forum 4 12-17-2008 08:41 PM
anti lock brake light problem redjeepcherokee ZJ Grand Cherokee Forum 3 01-20-2008 06:20 PM
Anti-Lock Brakes engaging rossj711 ZJ Grand Cherokee Forum 2 01-21-2006 12:38 PM
