antenna mast replacecment - JeepForum.com
post #1 of 6 Old 02-11-2007, 05:47 PM Thread Starter
alivenkickin28
tryin to replace the antenna mast. It is broken clean off at the bottom of the whole -- how would i get the rest of the mast out ?
1995 JGC Limited 5.2 v8, black with gold trim
1976 Olds 98, 82 Olds 98, 84 Olds 98, 89 Trans AM
alivenkickin28 is offline
post #2 of 6 Old 02-11-2007, 11:40 PM
drrm123
1994 ZJ
If nothing will extend when you turn the radio on or can't grab with needle nose pliers. you'll need to remove antenna and remove bolt in center of black cover to remove broken section. will need to remove inner fender well plastic and insulating foam and should be able to partially remove antenna to remove cover.
drrm123 is offline
post #3 of 6 Old 02-12-2007, 07:55 AM
H0miegwillikers
same thing happened to me, it looked like a pain to replace the stock antenna and i figured it would eventualy break off again so i went to advanced auto parts and bought the inside amplified glass mount antenna, MUCH easier to install
H0miegwillikers is offline
post #4 of 6 Old 02-12-2007, 09:17 PM Thread Starter
alivenkickin28
okay so you're talking about removing the tube from the actual motor assembly right?
post #5 of 6 Old 02-12-2007, 11:30 PM
drrm123
1994 ZJ
No I thought you had the mast out. If part of it is still on power antenna. The nut on the fender requires a special tool I just used some channel locks to remove. You can tape it or use something to protect the chrome if it matters to you. Once nut is off you should be able to pull remainder of mast out. There is a plastic part that is attached to the mast that's what I thought you had trouble removing. If it's not damaged you should be able to have someone turn on the radio and pull it out as it extends.
drrm123 is offline
post #6 of 6 Old 02-14-2007, 08:38 PM Thread Starter
alivenkickin28
yeah theres the little metal piece that is at the bottom of the mast that holds the antenna in the parked position when its down -- keeps it from goin into the hole furtner -- i cant get that part out -- but i have an extra tube i can switch out and attatch to the motor --
ZJ Electric Antenna Mast Replacement Tyrefryer ZJ Grand Cherokee Forum 11 08-22-2013 04:20 AM
Need solid mast antenna Baldman902 ZJ Grand Cherokee Forum 4 12-10-2009 03:03 PM
Antenne Mast wont go up, and can only pick up AM. bravo09 ZJ Grand Cherokee Forum 2 11-17-2008 10:52 PM
cant get antenna mast to pull in a70eliminator ZJ Grand Cherokee Forum 21 02-06-2008 03:19 PM
Replacement power antenna mast? MAUSS ZJ Grand Cherokee Forum 19 11-16-2005 07:34 PM
