Another towing question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > Another towing question
Jeep Restorations, Mild to Wild! CCORBead Lock Wheels! Raceline, Trail Ready, & Trail-GearVisit our new Jeep Store in Georgia
Unread 08-24-2009, 08:25 PM   #1
jeffrayy
Ok, I have come across a great deal on a fishing boat. It is a '15 fiberglass boat. I am guessing that the the weight of boat and trailer is about 2k pounds +. I have a '98 ZJ with the 4.0 liter. I am also going to be putting a 2 inch BB on when the parts come. The question is will the boat and the lift (I have 30 inch. tires) put too much strain on my tranny?
jeffrayy is offline   Reply With Quote
Unread 08-24-2009, 08:34 PM   #2
the88thpianoman
the88thpianoman's Avatar
2003 WJ
Not at all. I'd recommend adding an aux trans cooler, but the 4.0 and properly cooled 42RE can pull 2k pounds literally all the time and be just fine. My 4.0 and 42RE pulls up to 5k pounds on a fairly regular basis. I also have a 2.5" BB and will tow just as much when I eventually move up to a 4.5" lift.
WJ front drive shaft and fuse panel for sale
2003 WJ in Jeep Green Metallic, 4.0/242/4.10's. 4" Teraflex springs w/ RE monotube shocks and IRO short arms, cheap intake w/ amsoil filter, 2.5" hi flow cat and back exhaust, lots of lights and other misc crap.
Check out my build thread here: Life lessons and budget build
the88thpianoman is offline   Reply With Quote
Unread 08-25-2009, 09:46 AM   #3
jeffrayy
Great!!!! Now I have another question or maybe two. Should I get a regular, or heavy duty cooler? How difficult (or expensive if someone else does it) to put a cooler on?
Unread 08-25-2009, 09:51 AM   #4
1997ddzj
2k aint nothing. The big factor of towing with a ZJ is the brakes. But youll barely notice that load is even back there.
1997ddzj is offline   Reply With Quote
Unread 08-25-2009, 09:51 AM   #5
tsconver
2003 WJ
try to match the cooler to the GVW you will be at. Overcooling can also have ill effects such as putting the tranny in limp mode and preventing overdirve use when you are not towing.
Speak softly and carry a big stick.
We have room but for one flag, the American flag . . . We have room but for one language, and that is the English language . . . And we have room for but one sole loyalty...and that is a loyalty to the American people. T. Roosevelt 1919
2003 Grand Cherokee 4.0L Laredo
My Build Thread
A few goodies
http://s257.photobucket.com/albums/h...umb55839/jeep/
2001 Kawasaki 1200 ZRX
A few Speed parts, fun to ride
http://www.zrxoa.org/
2006 Red Liberty
Wife's ride, pretty stock
http://i257.photobucket.com/albums/h...mage0008-1.jpg
http://www.cnc4x4.org/
http://www.treadlightly.org/
tsconver is offline   Reply With Quote
Unread 08-25-2009, 10:16 AM   #6
SnowLeopard
Also, you might have the tow-prep package. Or do you have the full tow package from the factory? If it's the latter, you'll already have the 3.73 gearing and a tranny cooler along with the hitch and wiring. Check the hitch and see if it says Mopar. That can sometimes be misleading if a two package was installed later on by the dealer. So you'll probably want to check the build sheet to be sure. I thought I needed an aux cooler, and then I looked closer. I already had one. I had all the tow prep stuff but no wiring or hitch. I would definitely have your brakes checked out though. I know the ZJ's breaks are not the greatest.
Yes, it snows in Texas.
SnowLeopard is offline   Reply With Quote
Unread 08-25-2009, 10:36 AM   #7
jeffrayy
I am fairly certain that I don't have the tow-prep package. I add the hitch a few weeks ago and I still had the little bracket for shipping that was attached where the hitch should go.
What kind of upgrade to the breaks would be recomended? Are we talking new calipers and everything, or just upgraded rotors?
Unread 08-25-2009, 10:49 AM   #8
SnowLeopard
As far as I know, the stock brakes should be fine for towing as long as you aren't hauling anything overly heavy. I just know that mine aren't as great as they should be, still ironing that out. If you really want to get some good brakes though, PM Kolak. He'll set you up with some awesome rotors and pads. I've been considering it since I've had such annoying issues with my brakes.
