another tire question.. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > ZJ Grand Cherokee Forum > another tire question..
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LinePoison Spyder JK Body Mounted Tire CarrierBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 01-28-2014, 11:27 PM   #1
papitt
... Ok so a buddy of mine just stole a set of 31x10.50 15 for $100.00 I can't see a thing wrong with them. They are BF Goodrich AT'S . They are on ford 4x4 rims . Those aluminum wheels with about 15 holes all around the out side of the rim.
... I want to run something like this on my Jeep . Will these fit my jeep if I'm not wrong ford & Jeeps will interchange . I've been wanting to try a bigger tire.
papitt is offline   Reply With Quote Quick reply to this message
Unread 01-29-2014, 12:03 AM   #2
Myusername1674
Myusername1674's Avatar
Depends on the rim. 5x4.5 is what you need. Jack up the truck and try em worst thing that'll happen is you waste 10 minutes
95 FiveTwo ZJ, DD, Lifted, Locked on 35s, Build (in progress)
My 5.9 swap (in progress)
Want your zj to be doorless in 60 seconds?
Myusername1674 is offline   Reply With Quote Quick reply to this message
Unread 01-29-2014, 12:18 AM   #3
JasonStebbins
Most Ford Ranger wheels are 5 x 4.5
JasonStebbins is offline   Reply With Quote Quick reply to this message
Unread 01-29-2014, 08:03 PM   #4
papitt
oh no not A Ranger the real little CLASSIC Bronco 1972 Dana 44 ¶ 9 inch
Unread 01-29-2014, 09:18 PM   #5
big98tnzj
With it being old school like that its going to be a 5x5 or 5x5.5 bolt pattern. I wouldnt waste my time trying them unless you get different rims
Sent from my tent in the woods using JeepForum
big98tnzj is online now   Reply With Quote Quick reply to this message
Unread 01-29-2014, 11:04 PM   #6
papitt
Well you didn't read the top post. But no problem .. Their mounted on aluminum rims .. But no Issue they are gone sold . I wish I had not missed them .. I was just this close.
... Being No 2 in the prize fight Usually has your buddies picking you up off your ***!
